Fractal Define Nano S ITX Case Review
Stripped
As always when reviewing a case we take it totally apart. Â As the Nano S is predominantly metal though, there’s really only the plastic front and top covers to remove. Â Starting at the top then you can see the ModuVent system in all it’s glory. Â We’re sorry to keep harping on about this, but had they just called it a removable top panel we’d have been fine with it, it is, after all a good feature. Â it’s just the whole snazzy “ModuVent thing we’re having trouble getting behind. Â It’s kinda like saying a jam jar has a “Modulid” system, just because the lid comes on and off. Â What removing sound deadened top panel does do though is enable us to see the plentiful fan and radiator mounting slots that are present in the mesh roof panel.
Â
The base of the case also benefits from having a large mesh area and, as this may well be used as an intake, Fractal have fitted a full length dust filter which is easily removed via the front of the case without having to remove anything else first.
Â
The same cannot be said of the front filter though, as to get at this you first need to pull the front of the case off. Â Having done that the filter itself is easy to remove for cleaning and is robust enough to withstand a going over with a vacuum cleaner.
