Fractal Design Celsius S24 & S36 AIO Review
S36
S36
As you might imagine, the S36 shares most of its attributes with the S24, with the exception that it is a 360mm rad.  Yup, Ladies, as far as I can remember, we've never reviewed a 360mm AIO.  If this is the case, then this is a pretty momentous moment.  How will it perform, will it kick the 280s off the top spots, or is it a little lacking?  Well, if Fractal think their recipe is good with the S24 they've kept with it in the S36, as it shares the same 13 water channel and 20 FPI configuration as its smaller stable mate.
Where the S24 has two fan attachment points, the S36 has three.  Just a shame the lead on the furthest away fan isn't long enough to reach it!
It's a bit of a beast isn't it.  We're really excited to see how well it does.
The 400mm tubing should see the S36 able to reach back from the front of case position in which it will most likely see itself mounted.  But how many cases can take a 360mm rad?
We couldn't end this review without a group shot of the S24 and S36 together.  Between them they off quite a considerable cooling capability.
«Prev 1 2 3 4 5 6 7 Next»
10-05-2017, 15:14:13
AlienALX
Very nice. Love the fact that it uses "real" fittings to add to the aesthetics.
Shame it says warranty void on the fittings though. Fans don't excite me much either. Other than that though yeah man, bang on !
Ta for the review.Quote
10-05-2017, 15:28:16
WYP
Is it really £115 for the 360mm radiator? That is great value.Quote
10-05-2017, 15:29:45
AlienALX
It is. Add res and GPU block and you've got a capable yet cheap loop Quote
10-05-2017, 15:35:25
tinytomlogan
Risky flow rate with all that though :/Quote
10-05-2017, 18:01:13
NeverBackDown
Might just buy the S36. I'm a FD fanboy and these are beautiful AIOs... Ooooh the temptation is real
edit: Not available yet in the USQuote
