Fractal Design Kelvin T12 Review
Performance and Testing
The test set up consisted of the following
Intel i7 3960X [email protected] 1.1v (undervolted) 4.0GHz @ 1.25v 4.4GHz @ 1.35v 4.6GHz @ 1.45v Gigabyte X79 UD3 Corsair Vengeance LP Memory Corsair HX850 V2 Corsair Force GT 60GB Coolermaster Storm Trooper.
The graphs are now in jpeg format for all the mobile device users out there and are placed in order with the best performing at the top so as to help better visualise where the cooler we're testing comes in the pack.
As usual we'll be testing our coolers at varying levels of overclock and increasing levels of voltage.  This in turn of course means increasing levels of heat which the coolers need to dissipate.  To begin with we start with the undervolted stock speed.  Why undervolted? well if you have things set on "Auto", you may well be using more volts than are actually required to run at the chosen frequency, for example our 3960s will run quite happily at just 1.1volts, solid as a rock, 24/7, and as such we use this as our starting point.
Continuity is very important in testing, and for this reason we keep as many of the potential variables as locked down as possible.  We will be using OCCT in Linpack X64, AVX compatible with all logical cores tested and 90% free memory utilised. The test is set up to run automatically with just a few clicks to set it going.  A 10 minute idle followed by 30 minutes of testing and a 5 minute cool down is the order of the day and brings the total test time per clock speed to 45 minutes.  So as to remove subjectivity in determining whether a CPU has failed, OCCT is set to stop the test and register a fail should the max temp exceed 80 degrees.  In testing we noted that if even just one of the cores exceeds 82 degrees OCCT halts the test and a fail is recorded.
At this low level the T12 makes a fine entry in to the pack.  There may be a few tower coolers above it, but it does rank as the top 120mm rad based AIO.  Onwards and up wards then.
Turning now to the 4GHz test we up the voltage to 1.25 volts, this is what is deemed normally as stock volts. Something we are always harping on about on the forums is AUTO does not mean stock volts, and normally if you overclocking with "auto" volts the motherboard will be upping the volts much more than needed if you were to do it manually. By whichever means it happens, upping the volts (especially from our 1.1v undervolt) does have a big impact on temps, with an average increase of 10-15 degrees seen in the results.
At the higher levels of heat generated by the increase in voltage required for the 4.0GHz overclock, fan performance, although still a factor becomes less critical, replaced instead by a coolers ability to conduct the heat up the heat pipes and more crucially the total surface area of the fins enabling convection to the atmosphere.  In the case of AIOs and water cooling the surface area of the radiator and the efficiency of the contact plate begin to play more of a role.
Still the T12 holds its ground in the pack, but again there are some tower coolers above it, most notably the Noctuas.
Upping the volts still further we achieve a stable 4.4GHz overclock at 1.35 Volts. It's here we start to separate the wheat from the chaff, with lesser coolers not able to disperse the increased heat effectively. Again we see a jump of 10 degrees or so from the figures at 4GHz. Both the H100 and the well-respected D14 are creeping into the 70s here, indicating that only the cream of the crop will excel at this level.
At 4.4GHz quite a few of the lesser units have dropped off the charts.  Not so the T12 which is still holding its place as lead 120mm rad based AIO.
Only the most effective coolers are capable of making it into the hallowed 4.6GHz club and as you can see in the graph below there isn't a single air cooler in this graph, even the NH-D14 does not have enough cooling potential to be featured here. So all that has made this graph so far are the AIO big players and dedicated custom watercooling kits.
For a fleeting second we thought the T12 might actually make it into the 4.6GHz Club, but when you look at the S24s position in the charts in a recent review you'll see why it didn't.  The T12 has nothing to be ashamed of though as no other 120mm rad based unit has made it to these hallowed halls.
«Prev 1 2 3 4 5 6 7 Next»
20-02-2015, 13:08:19
Mullet
TTL - can you add the 4.6Ghz graph into the performance section of the review.
There's a reference to this chart in the review but the chart isn't shown.
Cheers!Quote
21-02-2015, 14:44:56
G-Dubs
It didn't make it into the 4.6 Club. There's a bit at the bottom of page 6.Quote
