Fractal Design Meshify C Review
Published: 9th August 2017 | Source: Fractal Design | Price: £79.99 |
If you're a fan of Fractal cases, you've maybe looked at the Define C and wondered what it would be like if they did a high airflow version to make the most of the extensive water cooling capabilities it possesses. If this is the case, then with more and more cases going down the tempered glass route, you may also have asked yourself how smart it would look with a smoked full size tempered glass panel. If you have been thinking these sort of thoughts, then it seems you're not alone, as that's exactly what the design team over at Fractal have done. Although familiar with the Define C, let's refresh ourselves by taking a gander at the all important vital statistics possessed by the Meshify C
Dimensions | 399x210x440mm (LxWxH) |
Mother Board | ATX, M-ATX, M-ITX |
3.5" | 2 |
2.5" | 3 |
Air Cooling | Front: 3x120mm or 2x140mm (1x120mm included) Roof: 2x120mm or 2x140mm Rear: 1x120mm included Base: 1x120mm |
Water Cooling | Front: Up to 360 or 280 Roof: Up to 240 or 280 Rear: Up to 120 |
Front I/O | Power/reset, HD Audio, 2xUSB3.0 |
Expansion Slots | 7 |
Max GPU Length | 335mm |
Max CPU Cooler Height | 172mm |
Weight | 6.8kg |
The "Meshify" name is terrible too.Quote
If they could only bring back the Arc series...Quote
Ugliest case they've done |
but doesn´t help... i don´t like it either.Quote
