Fractal Design Meshify S2 Review
It would be something of an understatement to say that Fractal have an extensive range of cases.  Take a look at their website, (linked above), and you’ll see that they cater for pretty much every element of your sub costal, cardiac pump’s desire.  So where then does the Meshify S2 fit into this extensive range?  Well, to be honest, right now we’re not entirely sure, but if you stay with us hopefully we’ll define the niche that the S2 fits into (Define…get it???… Nevermind)
Technical Specification
As we are currently pre-NDA, at the time of writing, there are no formal measurements or specifications for the S2.  We will though try to do our best to fill in a few blanks from pre-release information, and as details emerge we will further populate the table below.  For now though, here’s what we have.
Dimensions  538x223x456  (LxWxH)
Material Steel Chassis, Plastic trim, Tempered glass panels
Weight  9.52kg
Motherboard M-ATX, ITX ATX, EATX (up to 285mm wide)
5.25″  0
3.5″  3 (shared with 2.5″)
2.5″  7 (3 shared with 5.25″)
Front I/O  1xUSB3.1 gen 2 Type C, 2xUSB3.0, Audio in/Out
Expansion Slots  7 2 vertical
Air Cooling
 Front: 3×120/140 (2×140 included)
 Roof: 3×120/140
 Rear: 1×120/140 (1×140 included)
 Base: 2×120/140
Water Cooling
 Front: 120/240/360.  140/280 (max 147 mm width)
 Roof: 120/240/360.  140/280/420 (max 35mm   component MB Height
 Rear: 120mm
 Base 120/20. 140/280
Max CPU Cooler Height  185mm
Max GPU Length  440mm with front mounted 25mm thick fans
Max PSU Length 300mm
Â
