Inwin 703 Review
The Build
Inwin 703 Review
The Build
The accessories and instructions come in a nice sturdy zip lock bag.  Inside there's all the screws you need, nicely separated out and labelled.  You also get a Buzzer, a bag of rubber isolation dampers and three reusable cable ties.
Inwin 703 Review     Inwin 703 Review
Rather than being a booklet, the multi language instructions actually open out map style into a large sheet.  There's plenty of detail here but it can be a bit hard to work out where you are sometimes.
On to the build then and the first thing we do after installing the PSU is feed the 8 pin CPU cable through the small hole at the top of the case.  The reason for this is that it can't be accessed once the motherboard is in place.  The case is really quite easy to build into, and although there's not stacks of room there's enough.
With Water cooling firmly off the cards it's good to know you can get a decent sized tower CPU cooler in here.  anything up to 160mm in fact which should be plenty.  From a GPU standpoint, there's a good 408mm of room on tap which should take care of all but the most massive cards.
«Prev 1 2 3 4 5 6 Next»
15-07-2015, 06:03:40
Thelosouvlakia
Good review and all but I have a small request. Can you give Gary a black&red motherboard and gpu to use in "The build" section?Quote
15-07-2015, 06:12:44
tinytomlogan
I dont think colours really make a huge amount of difference for something like this matey - plus if I gave him a board Id need to send memory, a cpu, a GPU etc etc etcQuote
15-07-2015, 06:40:29
Tripp
Always loved in wins cases, a lot of there designs are a bit batty but that adds to the charm. This seems like a great basic caseQuote
15-07-2015, 06:50:03
AlienALX
/puts his tongue in his cheek.
No one going to complain it looks like a NZXT?
/removes tongue.
I love Inwin. I remember when they made the very first P4 certified case. I loved that thing, used hundreds of them.
They just went very quiet. Now? WHAM ! they're kickin' ass and taking numbers man. Good to see, hopefully at some point they will do a new version of their B52 stealth as it was never available in the UK (has a motorised front kinda like the Alienware I have).Quote
15-07-2015, 07:31:48
barnsley
I'm hoping the next review will be one of the nine series cases, especially the 909. Its good to see that In Win (who are my go to for interesting cases) have started to make reasonable budget stuff. Now if they could only make a minimal budget case..Quote
