Lian Li PC-A51 Review
Stripped
Lian Li PC-51A
Stripped
As there are no plastic fasciae on this case there's very little needs doing to strip it down.  The Aluminium front panel is secured in place by four small screws, which when removed allow it to be easily lifted away.  Doing so reveals the front PSU mount bracket and the other end of the IEC power cable (or kettle plug as most improperly call it).
Lian Li PC-A51     Lian Li PC-A51
The front panel must also be removed if you want to clean the filter.  We're not entirely sure why Lian Li have fitted a filter here, perhaps they themselves got confused and forgot this was an extract or maybe they're just being generous and providing it should you wish to change the airflow direction.  Up at the very top we find the stripped down front I/O and front cover mechanism for the 5.25" drive.  This mechanism is easily removed, as it has to be to fit a drive in here.
«Prev 1 2 3 4 5 6 7 8 9 Next»
17-06-2014, 07:20:22
YouWhat
Sounds strange, but if it works...
Link missing btw
http://www.overclock3d.net/reviews/c...c-a51_review/1Quote
17-06-2014, 07:22:05
tinytomlogan
Link missing btw
I was in the process of putting it live.....Quote
17-06-2014, 07:33:39
YouWhat
Sorry jumped on it too quick...Quote
17-06-2014, 07:37:32
tinytomlogan
I need a forum post before the front end stuff can go live.....Quote
17-06-2014, 08:01:21
barnsley
Lian Li stuff has grown on me so much and tbh while this case isn't exactly what I need...
Must. Not. Buy. hnnnng D:Quote
