Lian Li PC-O5S ITX Case Review
Lian Li  PC-O5S Review
Lian Li aren't exactly known for making "Normal" cases.  Sure they might make some enclosures that look like normal desk top towers, but for the greater part there's usually something about them that separates them from the pack, even if that certain something is merely the exemplary quality we've come to expect from Lian Li.  Where Lian Li really excel however is when they release their designers from their creative shackles, tell them not to produce "normal" and let their creative juices generate something truly unique.  Granted the end product is usually niche, and it has to be said more often than not quite expensive, but then, as they say, quality costs money, and so does innovation.  Let's put it this way, when Lian Li make a case you're not going to see multiple clones based on the same chassis from the same OEM are you?
So what's so special about the PC-O5S (yes that's a "O" not a 0, the font we use in the page header makes it look like a 0).  Well for a start it has an over sized tempered glass window.  That, and the fact that you can wall mount it, or even place it horizontally.  In fact, if Lian Li made bumper stickers this one would say " Lian Li does it Vertically, Horizontally, and Up against the wall".  Before we tell you too much more though, let's have a look at them all important Technical Specifications.
 Type  Mini Chassis
 Dimensions 465x384x148mm (HxWxD)
 Material Aluminium with Tempered Glass
 Colour Black
 Weight 6.4kg
 Motherboard M-ITX
 5.25" 1x Slim ODD (1x3.5" or 1.2.5")
 Storage behind M'board tray 3.5"x1 + 2.5"x1 or 2x2.5"
 Storage on M'board tray 3.5"x1 + 2.5"x1 or 2x2.5"
 HDD Rack 3.5"x3 + 1x2.5"
Expansion Slots 4
 Cooling
 Top:  2x120mm
 Side: 1x140mm (Optional)
 Front I/O USB3.0 x 2, HD Audio
 Max GPU Length 190mm (175mm when using a VGA card with a front-located power plug)
 310mm(Remove HDD rack)
 Max PSU Length 140mm (SFX PSU)
 Max CPU Cooler Height 85mm
 Space for Radiator 60x300x130mm (HxWxD)
  PCI-E Riser Cable 1 (Gen 3.0)
«Prev 1 2 3 4 5 6 7 8 Next»
27-11-2015, 03:24:46
ToneEQ
I do have a soft spot for Lian Li cases, and for a brief moment I was considering this case instead of the Corsair Obsidian 250D, until I saw the price!Quote
27-11-2015, 08:58:16
AlienALX
Wish they would bring back the fish tank case Quote
27-11-2015, 09:37:37
barnsley
Lovely. I'd be tempted too if it wasn't for the price. I have what is probably its closest competitor (the in win 901) and it is about half that price now. If they were to lop £50 off then it'd be a huge 'maybe' as I'd love some rad space.Quote
27-11-2015, 11:23:52
demonking
I know that Lian-Li are really good quality but they have never been competitive in price.Quote
27-11-2015, 14:15:09
ToneEQ
Completely agree. Cheapest I can find this is ~£235, that's more than what my PC-80B ArmorSuit cost (and much more room inside).Quote
