Lian Li PC-O5S ITX Case Review
Up Close: Interior
Lian Li  PC-O5S Review
Up Close:  Interior
Removal of the tempered glass side panel grants us access to the interior.  Towards the top we can see the large CPU cut out, almost as large as the M-ITX board itself in fact.  You'll also notice a large ribbon data cable.  This, as we'll see later is to enable PCI cards such as your GPU to be mounted vertically within the case.  The are also a number of other cut outs, but rather disappointingly none of them have grommets.  Maybe it's just us, but we can't help feeling that a case such as this, that puts everything on show and is designed to present your hardware at its very best should have the facility to hide as much of the cable clutter as possible.
Lian Li  PC-O5S Review     Lian Li  PC-O5S Review
The PC-O5S accepts only the SFX PSU.  A few short years ago this would have been a bit of a no-no, but decent SFX PSUs can now be had without having to first sell a Kidney.  The PSU is mounted vertically in the top front corner of the case effectively hanging from the bracket.  Although at first it appears there's little ventilation for the PSU, it is in fact quite cleverly thought out.  With the PSU mounted with the fan towards the window, there's a gap between it and the glass.  This gap communicates with the mesh panel at the front which will enable it to suck in fresh air.  Hot air is then exhausted out the rear of the PSU which is in turn vented out of the roof of the case.  Directly below the PSU bracket we find the main HDD rack.  This rack is able to accept up to three 3.5" HDDs plus an additional 2.5" drive and uses rubber O-rings to isolate vibration from the spinners.
To the left of the Main HDD rack there's quite a busy little area.  Firstly, as you can see this is where your GPU is going to live, with the PCI-E 16x Gen 3,0 riser cable enabling the card to be mounted parallel to the motherboard.  This not only saves space and allows minimal case thickness, but also enables it to be seen face on through the window panel.  There's also room here on the motherboard tray for 1x3.5" and 1x2.5" or 2x2.5" drives.  Doing so will mean that the PCI card has to be mounted further out on its runner, and will entail the loss of a PCI slot, but if you absolutely have to have more storage it's always an option.
There's no rear fan as such on the PC-O5A, but the rear of the case is very well ventilated.  Up in the roof however you do get a pair of 120mm fans set to extract.
«Prev 1 2 3 4 5 6 7 8 Next»
27-11-2015, 03:24:46
ToneEQ
I do have a soft spot for Lian Li cases, and for a brief moment I was considering this case instead of the Corsair Obsidian 250D, until I saw the price!Quote
27-11-2015, 08:58:16
AlienALX
Wish they would bring back the fish tank case Quote
27-11-2015, 09:37:37
barnsley
Lovely. I'd be tempted too if it wasn't for the price. I have what is probably its closest competitor (the in win 901) and it is about half that price now. If they were to lop £50 off then it'd be a huge 'maybe' as I'd love some rad space.Quote
27-11-2015, 11:23:52
demonking
I know that Lian-Li are really good quality but they have never been competitive in price.Quote
27-11-2015, 14:15:09
ToneEQ
Completely agree. Cheapest I can find this is ~£235, that's more than what my PC-80B ArmorSuit cost (and much more room inside).Quote
