Lian Li PC-O7S Review
Having recently looked at the M-ITX Lian Li PC-O5S, it's now time to break out the wide angle lens and get to grips with the Aluminium and Tempered glass monolith that is the PC-O7S.  Why wide angle?  Why Monolith?  Well have a look at the measurements, at 585x514x148mm (HxWxD), the PC-O7S is simply huge, even for a full size ATX case, and at a smidge under 10kg it's no lightweight either.  Granted most of that weight comes from the massive tempered glass side panel, and not from the hair brushed Aluminium chassis and panels, but 10kg is still 10kg.  If you've seen the reviews of its stable mates you'll already know that like them this case is designed to be wall mounted, as well as traditionally with the included stand, or horizontally with the optional feet.  However, all that glitters is not necessarily gold (or deep black Aluminium for that matter), so best we have a look at the Technical Specifications and see what the PC-O7S has to offer on the inside.
 Model PC-O7S
 Case Type Mid Chassis
 Dimensions 585x514x148mm (HxWxD)
 Materials Aluminium chassis and panels with Tempered Glass Panel
 Colour Black
 Weight 9.9kg
 5.25" 1xSlim
 Storage Behind Motherboard Tray 1x3.5" + 2x2.5" or 2x3.5", or 3x2.5"
 Storage In Front of motherboard Tray 3x3.5" or 3x2.5" (Occupies PCI slot space.)
 HDD Rack Storage 3x3.5" + 1x2.5"
 Expansion Slots 4
 MB Type E-ATX, ATX, SP-ATX
 Cooling
 Roof:           3x120mm
 Side panel:  1x140 (optional)
 Front I/O 4xUSB3.0 HD Audio
  PCI-E 16X Riser Cable 1(Gen 3.0)
 Max GPU Length 310mm (410mm with HDDD rack removed)
 Max PSU Length 220mm
 Max CPU Cooler Height 85mm
«Prev 1 2 3 4 5 6 7 8 9 Next»
05-07-2016, 16:18:31
MisterComputer
Tom, it's a bit late to spot this I suppose, but I think there has been a BIG oversight here. Take a look at the Lian Li product page for the PC-O7. The PSU bracket is clearly lower in the product photos than it is in your review sample, by about an inch. Also, the comment you made about the PCI riser cable only reaching the lower slot reminded me of a review I'd seen elsewhere which had the same problem, but it was said to be due it being pre-production and all production models would be shipped with the longer cable.
Anyway, if that gap between the PSU and top IS indeed bigger in the production version of the PC-O7, it would make watercooling easier and allow for a thicker rad up top possibly.Quote
