Lian Li PC-O7S Review
The Build
The Build
The accessories bag that comes with the PC-O7S is absolutely crammed, as it should be when you buy a £355 case.  In total you get the following; a cover plate for the HDD cage, a load of rubber isolation grommets, 4 cable management clamps, a hand ful of cable ties, 4 rubber feet for the PSU mount area, a USB adapter, a pair of molex fan adapters, a buzzer and of course all the usual screws etc.  On the not so good side, the instructions, although extensive are hard to follow and have truly miniscule black and white images.
Lian Li PC-O7S Review     Lian Li PC-O7S Review
And so to the build.  First to go in is the PSU.  Although the PSU is actually hung from the mounting bracket, it's actually easier to attach it with the case on its side.  Lian Li provide four rubber pads to attach to it to prevent it vibrating off the side panel once in place.
Even with the case on its side it's still a bit of a fiddle to secure, especially with the chromed strengthening rod being in exactly the wrong place and as such obscuring two of the thumb bolt holes.  The mother board though is easier to place with Lain Li favouring narrow thumb bolts here as opposed to the more common simple screw.
With 310mm of room to play in, our old EN8800GT is positively dwarfed.  If you need more than 310mm then whipping out the HDD rack will up the space available to a staggering  410mm
«Prev 1 2 3 4 5 6 7 8 9 Next»
05-07-2016, 16:18:31
MisterComputer
Tom, it's a bit late to spot this I suppose, but I think there has been a BIG oversight here. Take a look at the Lian Li product page for the PC-O7. The PSU bracket is clearly lower in the product photos than it is in your review sample, by about an inch. Also, the comment you made about the PCI riser cable only reaching the lower slot reminded me of a review I'd seen elsewhere which had the same problem, but it was said to be due it being pre-production and all production models would be shipped with the longer cable.
Anyway, if that gap between the PSU and top IS indeed bigger in the production version of the PC-O7, it would make watercooling easier and allow for a thicker rad up top possibly.Quote
