Lian Li PC-O7S Review
The Build Continued
The Build Continued
The GPU is connected to the Motherboard via a Gen 3.0 PCI-E 16x riser cable.  Unfortunately the cable is only long enough to reach the lower PCI slots on the motherboard.  Not a problem if all your slots are rated the same, but you're going to be mighty miffed if you the cable will only reach the slower slots at the bottom.
Lian Li PC-O7S Review     Lian Li PC-O7S Review
Even without rubber grommets we can still achieve a reasonable cable job on this limited build.  We can't help thinking though that nicely executed geometrically cut rubbers would have made the interior look just that little bit nicer.  You'll have to decide for yourselves how you feel about it.
Although there are no cable tie points, Lian Li do provide 4 big "P" type self adhesive cable anchors to help things round the back.  The deep and wide trough at the bottom also provides a great place to hide any unwanted lengths.
«Prev 1 2 3 4 5 6 7 8 9 Next»
05-07-2016, 16:18:31
MisterComputer
Tom, it's a bit late to spot this I suppose, but I think there has been a BIG oversight here. Take a look at the Lian Li product page for the PC-O7. The PSU bracket is clearly lower in the product photos than it is in your review sample, by about an inch. Also, the comment you made about the PCI riser cable only reaching the lower slot reminded me of a review I'd seen elsewhere which had the same problem, but it was said to be due it being pre-production and all production models would be shipped with the longer cable.
Anyway, if that gap between the PSU and top IS indeed bigger in the production version of the PC-O7, it would make watercooling easier and allow for a thicker rad up top possibly.Quote
