Lian Li PC343 ATX Case
Testing & Results
Published: 6th April 2008 | Source: Aqua-PC's | Price: £220 |
Temperature results
To ensure that we didn't give the PC-343 any unfair advantages, only the stock fans provided with the case were used during the testing. In addition to this, all fans were connected directly to a +12v molex to prevent any potential skew in the results from the motherboard trying to manage the fan speed.
Temperature readings for the CPU and Case were taken using Asus' PC Probe, GPU was taken using ATITool and Hard Disk directly from S.M.A.R.T. While we fully understand that these results may not be entirely accurate when compared with a digital thermal probe, they serve perfectly well when results conducted with the same core hardware.
Even with four 120mm fans running at 100% this case is still not over powering, its only the graphics card fan in this set up you can hear. Most surprisingly for me an everyday Raptor user is the HDD cage has silenced it. Even when testing the drives for temperature I couldn’t hear the Raptor or 750gb drives clunking away like they usually do. I had to take the side panel off at one point and put my ear to them to check everything was ok!
Originally Posted by name='Toxcity'
Looks to be a fantastic case!
Very pleasurable read Jim. ![]() |
Originally Posted by name='Jim'
Not my review mate
So what do you think for my 1st review on oc3d? Ive put poor old Jim through hell getting this done!Quote
Im sure will help many when making the decision between similar specced cases when it comes to cooling options and build quality.
Its amazing stuff that Nescafe isnt it
Keep up the good work and look forward to many more reviews.Quote
Very pleasurable read Jim.......Tom!?!Quote
