Lian Li TYR PC-X500 Chassis
Cooling, Assembly & Cable Management
Published: 14th October 2008 | Source: Lian Li | Price: £250 |
Cooling
There are a total of four 120mm fans provided within the X500, two act as intakes on the front, and the other two act as exhausts on the rear. Each fan is complete with a matching grille, and can be powered by molex or via a 3-pin header. The two front fans can be connected to the inbuilt fan controller by removing the molex connector and using the supplied header plugs. We shall discuss the effectiveness of this setup further in our testing page.
Motherboard: ABit IP35 Pro Skt775
CPU: Intel Pentium Dual Core E2200 with stock HSF
Memory: 2GB Geil Ultra DDR2-800
GPU: Powercolour Radeon HD4850
PSU: ThermalTake ToughPower 750w Modular
Hard Drive: Hitachi SATA II 160GB with clean install of Windows XP SP3
Assembling the PC inside the X500 was a breeze. There were no unwelcome surprises and Lian Li have provided all the screws and fittings necessary for the build. This is one of the few chassis that I have worked on, that hasn't resulted in cuts on the hands. If you were to spend time looking for sharp edges within the chassis, you would probably fail. Little things like this deserve merit as it shows that the manufacturer has given their product thought. Assembly took me around 25 minutes to complete, and the chassis was a joy to work on. With all the little extras Lian Li provide, it does make the task much easier.
I found that managing the cables within this chassis was a lot easier that with the X2000, and this was down to the reduced height of the chassis. This reduced height meant that routing the PSU cables was a lot easier and resulted in a tidier finish. Also, there is a gap between the right side panel and the motherboard tray, which enables the concealment of the slack on cables. When I assembled the chassis, I used only what Lian LI provided to manage the cables, and I got good results within the motherboard compartment, with very little effort. On the reverse of the motherboard was a little untidier, but this was more down to me not spending enough time to arrange the cables, due to time constraints. Overall, I was very happy with the results.
On the next page, we shall put the X500 through its paces.
Thanks mate, it does take some getting used to having to go round the side for the DVD's, keep going for the front without thinking
Quote
The Tyr cases, eventhough "fitted" for watercooling, is better suited for regular cooling (fans) than water. If you do want water theres allmost no room inside for pumps, radiators, reservoirs. Though, you don't have to cut holes for hoses if you've got an external kit anyway
But I never buy anything but LianLi anymore.... All aluminium cases are easier to cut/modify and extremely lightweight.
Very good and balanced review btw.
-BubbaQuote
-BubbaQuote
![]() But I never buy anything but LianLi anymore.... All aluminium cases are easier to cut/modify and extremely lightweight. Very good and balanced review btw. -Bubba |
I am sorely tempted to try and get a 240mm rad in on a CPU only loop
Probably in the front.. What I was contemplating though were 4x120mm radiators, though I weren't entirely sure where to place the pump and reservoir.. With some serious graphics solutions like sli, trisli or quadsli, there's simply no room unless you ditch all harddrive cages and cdr's.. which you can if you use SSD disks and external CD-rom... but if it's worth it.... Then I rather go with some generic box like PC70A.. which is like the coolermaster stacker, just an empty box with loads of 5.25" drivebays and nothing fancy.
-BubbaQuote
-BubbaQuote
Great review fella
