Lian Li V1010 Aluminium PC Case
Internals & Installation
Published: 12th December 2008 | Source: Lian-Li | Price: £125.24 |
Internals
The internal of the v1010 are very nicely laid out, with quite a few genuinely useful features. All of these should help to make installation a lot easier and pain free...
Installation in the v1010 was an absolute joy. Not only is it very simple, but it is incredibly easy to build a nice looking pc.
First of all we prepped all the hardware outside of the case. We installed the motherboard on the tray with CPU and cooler attached, whilst also adding the grommets to our hard disk.
As you can see, the v1010 has a sensible layout. The hard disks are stored down on the bottom along with the PSU and everything else is kept up top. The central pillar gives extra support for expansion cards whilst also providing a nice 'alley' for channeling wires up. The motherboard tray is removable, which will aid installation significantly. As you can see, Lian-Li have taken the liberty to cut cable holes in the tray, which should give a very neat final set up.
Installation
With that done, we put all the gear into the case. We slotted in our PSU, a Silver Power model. There is a gap under the PSU, which seemed perfect for shoving all the unneeded leads under. The rest snake under the motherboard tray and through to the motherboard.
Finally add all the PCI cards, and you end up with something that looks like a fully functioning PC. As we didnt have any particularly long graphics cards to test, we weren't able to test out the central stabilisation bar. As you can see, it is incredibly neat. There are only a few cables visible, and this should definitely help airflow.
Nice review. I do like Lian Li cases.. They seem to have clean simple lines, shame they are up the top end of the price bracket. If the devil is reading this: I'm prepared to give you the first born child from the next 10 generations of my family if you get me one
Quote
I also love that Lian Li always have a "little and large" thing going on, theres always a smaller version of all their super towers. V1010 to the V2010, A17 to A77, A10 to A71.
