Nanoxia CoolForce 2 Review
Up Close: Â Exterior Overview and Front
The CoolForce 2 is of average size for a mid tower, measuring as it does 430x200x475mm (HxWxD) Â Like many cases it has a steel chassis and makes use of plastic moldings to provide the exterior aesthetics. Â The shut lines on the case are good, although there is slight variance in the shades of black seen between the different materials. Â The left hand side panel sports a 3/4 length, half width window, and although it will show off the motherboard area, you’re not going to see much forward of your RAM slots.
Â
The front I/O is placed at the top edge of the front of the case and has a a single USB 2.0 and a pair of USB 3.0s. Â The power button is centrally located, to the right of which there’s a small reset switch. Â Next to these we then find a three position fan controller and a pair of audio sockets.
Â
The front of the case is minimalist in design, with the heavy bevel giving it a slight Corsair Graphite series look to it, which is no bad thing. Â The clean lines of the plastic, line brushed Aluminium effect front panel are broken only by the covers for the pair of 5.25″ bays. Â The case front is stood off slightly from the bevel which allows for at least some air flow. Â Also unseen but present are rows of Green LED lights which border the lower two thirds and floor of the bevel’s interior edge.
Â
There are a couple of nice little details present on the front panel, the first of which is the Nanoxia logo, which is placed under the bevel at the top of the case. Â This logo lights up Green when the case is powered. Â Down in the bottom left corner of the case there’s an aesthetic break in the bevel which also allows for the placement of a small button used to control the case front lighting. Â Pressing the switch toggles the lighting through off, side lights, and logo lights so the desired effect can be achieved by the user.
   Â
