Nanoxia CoolForce 2 Review
Up Close: Interior, Rear and Stripped.
The rear of the motherboard is nicely laid out with a good 18mm of space on offer for cable management, You also get some simple Velcro style ties on the main cable tie points and although there are a few more cable tie points more of them would definitely be appreciated.  There's also a stealth mount for a 2.5" drive back here, so if you've removed all the storage from up front you've still got somewhere to mount your SSD.
Nanoxia CoolForce 2 Review     Nanoxia CoolForce 2 Review
In the bottom left hand corner there's a pair of metal drawers for 3.5" drives, with the dual 5.25" bay located at the very top corner.  As we mentioned previously, all these can be removed to make room for rads and the like.
The front of the case pulls off very easily, but as the cables are tethered through care is needed to ease it away from the chassis.  Doing so reveals the pair of 140mm fans that come with the case.  Mounting points are also available here for 120mm units.
«Prev 1 2 3 4 5 6 7 Next»
