Noctua go all black for Computex 2018
Redux NH-U12 - A Hyper 212 competitor & Video
Published: 8th June 2018 | Source: Noctua @ Computex | Price: |
Redux - A Hyper 212 competitor
Noctua's Redux line is designed to offer fans a lower-cost to deliver a low-cost entry point into the Noctua ecosystem. The Redux brand is now moving into the heatsink market, with Noctua planning a lower-cost derivative of their NH-U12S, bringing the brand into a lower price bracket with a few notable design tweaks.
This prototype unit, for example, has had its aluminium heat fins press-fitted and not soldered onto its attaches heatpipes, and Noctua plans to remove one or two heatpipes from the final version of the NH-U12S Redux, allowing the unit to enter a lower price bracket and potentially become a Noctua value performance champion in the CPU cooling market.
You can join the discussion on Noctua's presence at Computex 2018 on the OC3D Forums.
Video
It's still annoying how the all black fans aren't even for there newest fan..
But this new 120mm fan, it's like going back to the roots of Noctua where they were one of the only companies to consider if you wanted extreme performance at low noise levels. They can afford to go back to what they clearly prefer, which is a very distinguishable colour combination, as the fan's performance has no equivalent. No other 120mm fan performs as well. If I had that kind of power, I would want to distinguish my product visually as well.Quote
Yeah, but I can see why. The beige and tan is Noctua, and up until now has been a way to distinguish them as extreme performance fans. Now the market is a lot more competitive. We have dozens of equally awesome, if not better fans that are just black, or black and grey, or black and white. They can't solely rely on their performance to sell fans any more.
But this new 120mm fan, it's like going back to the roots of Noctua where they were one of the only companies to consider if you wanted extreme performance at low noise levels. They can afford to go back to what they clearly prefer, which is a very distinguishable colour combination, as the fan's performance has no equivalent. No other 120mm fan performs as well. If I had that kind of power, I would want to distinguish my product visually as well. |
The Scythe, who no longer is a company, but the current Nidec Servo(oem for scythe) makes the Gentle Typhoons. They are and were the best static pressure fan bar none. Not even the infamous NFF12 could beat it really. They had most of the current technology Noctua has in there newest fan but from years ago in addition to a more simple and cheaper design.. but now they are hard to find and only limited selection.
With that said having owned the GTs(4) I actually just bought Noctuas latest fans and also bought the Chromax A14. So I can now compare. As far as specs go the Noctuas newest fan has more static pressure but less airflow. So testing should be interesting.Quote
