Noctua NC-U6 Chipset Cooler
You can see from the picture below, how the supplied sticky foam pad protects the transistors on the Intel 965P Northbridge. Please excuse the sticky residue left over from my Jin Ting cooler, as it was extremely difficult to remove all traces of it.
Installation of the Noctua NC-U6 on my ASUS P5B Deluxe was an absolute breeze. The spring loaded plastic lugs made the installation process the quickest that I've ever had when changing NB coolers. The pressure applied to the chipset itself was firm and felt very secure.
NC-U6 front NC-U6 side
The NC-U6 chipset cooler provides ample clearance from any of the surrounding capacitors on my motherboard, and at least a good 35 - 40 mm (or just over 1.5" for those who use the Imperial system) from the PCI-E graphics card slot.
NC-U6 showing height from waterblock NC-U6 showing distance from gfx card
The above two pics show just how versatile the NC-U6 is as far as ensuring system compatibility. Even with the the heatsink rotated, there is still ample room left for large aftermarket CPU heatsinks to be installed.
So how does the NC-U6 perform as a purely passive heatsink? Will it be able to withstand the rigours of testing Australian summer temperatures? Follow me onto the next page to see how it handles the heat.
«Prev 1 2 3 4 5 Next»
14-02-2007, 08:42:46
Looks damn sweet. Great review as usual Mr Peevles Quote
14-02-2007, 09:31:13
Thanks mateQuote
14-02-2007, 09:47:31
Looks really nice, I think the price tag isn`t too bad either. Definately something to consider to replace some of the awful ones mobo manufs put together.
Thing that amazes me is if u look at the item seperately, it looks like it`ll be an awkwardly looking skyscraper of a hs. But when u see it mounted in situ, surrounded by cards etc, u realize it`s more suitable than u might have thought.
Price I seen this @ Performance was about $35 >.< I was thinking it`d be cheaper dollar side.Quote
14-02-2007, 10:48:54
Mr. Smith
That is a nice little cooler. Quality review too Quote
14-02-2007, 14:44:27
Nice review. PV, how'd you measure chipset temp on P5B?Quote
