NZXT HAVIK-120 Review
Up Close: Packaging and contents
 NZXT HAVIK-120
Like the fans within, the box housing the cooler is also monochrome black and white. And very classy looking it is too. As well as the usual pictures and graphical representations of the cooler the exterior of the box gives technical specifications and key features.
NZXT HAVIK-120     NZXT HAVIK-120
The Havik 120 comes nicely nestled in a protective shell of expanded foam, with additional sections of the material providing both support and protection. The unit comes with both of the 120mm fans contained within the packaging although they will require attachment to the body of the cooler
As you would expect the unit comes with a mounting system that accommodates pretty much any CPU you care to stick it on top of, including LGA2011 of course. Instructions are clear and informative with diagrams and text walking you through the process of installation. Also included are a pair of Y splitter cables allowing the fans to be united into one header. The splitters provide for high and low speed respectively. Finally NZXT have added some TIM and a spare fan attachment Bungee (looks like they have listened to Tom as this was an omission with the 140) and you've got yourself a pretty comprehensive set of kit.
«Prev 1 2 3 4 5 6 Next»
04-04-2012, 11:00:25
chudley
Nice review Gary, As I am on the daughters laptop atm I had to scroll up and down to compare fan results, what might help others in the future would be a vertical red bar of the temps achieved by the item in question.going up through all results for easy comparison.Quote
04-04-2012, 11:28:22
Excalabur50
Sounds great for those with limited space or a tight budget seems NZXT are lifting their game nice to see.Quote
04-04-2012, 14:04:52
Jason-CL
It's because we've upped the amount of time we spend whipping our designers, I assure you. :b
Quote
04-04-2012, 17:52:55
G-Dubs
the 120 really is a nice bit of kit. Whatever it is NZXT are doing it seems to be working.
This lady with the whp, does she take bookings? Quote
04-04-2012, 17:55:54
Ghosthud1
£46 seems steep for a heatsink of this performance level. Actually all heat sinks are starting to sink into much higher price brackets! what happened to the ocz vendetta that stomped everything at £28Quote
