NZXT Kraken G10 GPU Heatsink Review
NZXT Kraken G10 Review
Up Close:  Packaging and Contents
The Kraken G10 comes packaged in quite a flimsy card box, the exterior of which shows images of the product within as well as graphs relating to the expected performance gains.
NZXT Kraken G10 Review     NZXT Kraken G10 Review
Although NZXT may have scrimped a bit on the box they’ve certainly pushed the boat out on the internal packaging, with layers of expanded foam cosseting the contents, the star of which is the G10 bracket itself.
Aside from the actual bracket you also get a two tone 92mm fan, a matching back plate and all the screws you should need (alternative screws are available for specific coolers listed in the Technical Specification).  You also get a set of instructions and a slack handful of cable ties to help tame the various tubes and cables you’re likely to need to wrangle as part of the fitting.
NZXT Kraken G10 Review     NZXT Kraken G10 Review Â
