NZXT Noctis Gaming Case 450 Review
NZXT Noctis 450
Unless you've had your head buried in the sand or inserted somewhere tighter but less pleasant, you'll know that the H440 from NZXT was the first case ever to be awarded Tom's White Gold award.  The reason for this was that aside from its obvious attributes Tom considered it a case he himself would like to own and would actively pursue.  Praise indeed.  So where does the Noctis 450 fit into this you may ask?  Well, it shares much of the same internals and chassis as the H440 but is aimed more at the gamer/performance end of the market than the H440 which has more of a low noise profile.  Needles to say, the pressure is certainly on it to perform, and just one look at it will tell you that it doesn't intend to take in prisoners in the aesthetics department.  Is it performance perfection personified?  Well you'll have to read on to find out...
 Dimensions 220x567x544mm
 Motherboard Support ATX, M-ATX, M-ITX
 Weight 9.5kg
 Material SECC Steel, Plastic
 Cooling
 Front:  3x120mm fans included
            2x140mm Optional
 Rear:   1x140mm included
            1x120mm Optional
 Roof:    3x120/2x140 Optional
 Radiator Support
 Front:  Up to 280/360mm
 Roof:   Up to 280/360mm
 Rear:  120/140mm
 Expansion bays 7
 Front I/O 2xUSB3/2xUSB2, HD Audio
 3.5" 6 Shared with 2.5"
 2.5" 6 Shared with 2.5" +2
 Max GPU length 294mm/ 406.2mm
 Max CPU Height 180mm
«Prev 1 2 3 4 5 6 7 8 Next»
28-04-2015, 14:58:38
Doomslayer
To me this case looks like a combo on the H440 & a Phantom case unless that is the idea. Still looks nice thoQuote
28-04-2015, 15:00:13
Feronix
The front reminds me a lot of the old Lexa S with a bit of Phantom and a Switch/Phantom window.
Personally I think it looks horrible :|Quote
28-04-2015, 15:04:42
Doomslayer
IMO It doesn't look no where near as good as the H440, From what you're saying is it looks like they just threw it together.Quote
28-04-2015, 15:42:03
MadShadow
Have a look at the black version, you may like it better Quote
28-04-2015, 15:44:33
barnsley
NEED FOR SPEED
the case.
Not a fan at all. Its a shame as they've been on a role aesthetically recently.Quote
