NZXT Noctis Gaming Case 450 Review
Up Close: Interior
NZXT Noctis 450
Up Close:  Interior
If the interior of the 450 looks cramped it's because NZXT have very kindly blanked off the area where the drives live.  This area wouldn't be visible through the window anyway, but it's still nice to have clean lines.  The downside though of this is that the upper extent of the panel can be seen through the case window and any hoping to mod their window to show a fat rad in the front of the case will also have to remove this panel as it shields the area from view.  In reality the interior is as spacious as any other to work in and benefits from a decent sized CPU cut out as well as several well spaced cable management grommets.  The three vertical ones being angled slightly in so as to make turning cables that little bit easier.
NZXT Noctis 450     NZXT Noctis 450
Down at the bottom of the case we see that NZXT have included a full length PSU/cable cover.  While we really like the cover, we do have to say that we're a bit disappointed that the NZXT logo cut into it illuminates blue.  This we feel limits the serious builder, the sort who likes to see all his kit and lighting match to having a blue themed build.  A more obvious choice would have been white as being a neutral colour this would have left the door open for any interior themes.  On a more positive note, the roof of the PSU cover has a pair of 2.5" SSD show off mounts, with a set of corresponding cable routing holes.  We'd strongly recommend using either the end of a SATA power cable or a separate cable run from the PSU to each of these to keep things looking tidy.
At the rear we see the seven vented PCI slot covers.  Eight would have been nice as it would have given a bit more room for any expansion cards or multi GPUs mounted low down to breath.  Up in the roof though there's plenty of breathing room with the raised roof offering tons of space for fans.
«Prev 1 2 3 4 5 6 7 8 Next»
28-04-2015, 10:58:38
King of Old Old School
To me this case looks like a combo on the H440 & a Phantom case unless that is the idea. Still looks nice thoQuote
28-04-2015, 11:00:13
Feronix
The front reminds me a lot of the old Lexa S with a bit of Phantom and a Switch/Phantom window.
Personally I think it looks horrible :|Quote
28-04-2015, 11:04:42
IMO It doesn't look no where near as good as the H440, From what you're saying is it looks like they just threw it together.Quote
28-04-2015, 11:42:03
MadShadow
Have a look at the black version, you may like it better Quote
28-04-2015, 11:44:33
barnsley
NEED FOR SPEED
the case.
Not a fan at all. Its a shame as they've been on a role aesthetically recently.Quote
