NZXT S340 Elite Review
Up Close: Interior rear of Motherboard
Published: 19th October 2016 | Source: | Price: 94.99 |
NZXT cases have always had well thought out and spacious rear of motherboard areas, with ample cable management space, and we have to say that Elite is no exception. Not only are there more cable tie points than you can shake a...well a cable tie at, but there are also several built in plastic cable management clips situated along the main cable routing paths.
The PSU mount is towards the rear of the case and is accessed by removing a rear panel. There's plenty of room in the PSU area for even the longest PSUs to find a home.
At the front of the case, under the false floor there's a small rack for the accommodation of 2x3.5" drives. The floor above the rack does have a degree of ventilation so the old spinners aren't going to get too hot and bothered.
The metal front panel comes off with a firm tug, revealing the magnetically attached front intake filter. Interestingly, it isn't actually necessary to remove the front panel to remove the filter as it can be detached and lifted out through the rectangular aperture anterior to the front I/O
If the price drops to around £65 i buy one
Could anyone with experience with the case look into, and tell me if i could fit the CEB board and would problems I may face, Thanks. (:Quote
--Rick--Quote
