OCZ Gladiator MAX CPU Cooler
Test Setup
Test Setup
To ensure all our CPU cooler tests are as equal as possible we intend to use the same base setup, CPU clockspeed and BIOS settings. We also take special consideration to ensure that the ambient temperature is as near to 23 degrees centigrade as possible throughout the testing thanks to an digitally controlled air conditioning system.
CPU Coolers:
Intel Stock i7 920 skt 1336 cooler
Asus Triton 81 HSF
OCZ Gladiator Max
CPU: Intel Nehalem i7 920 Skt1366 2.66GHz
Motherboard: DFI X58 T3eH8
Memory: 3x2GB Corsair Dominator DDR3 1600mhz @ 8-8-8-24
HD : Hitachi Deskstar 7k160 7200rpm 80GB
GPU: Nvidia GTX280
Graphics Drivers: GeForce 180.60
PSU: Gigabyte ODIN 1200w
Fitting the cooler with the Skt1366 kit was a little fiddly as I did not wish to stick the backplate to the motherboard and as you can see, the 1366 fitment does not have protrusion that fit through the motherboard like the skt775 backplate has. Once screwed down however a solid and excellent mount was achieved thanks to the chromed screws and springs.
cooler fitment backplate
Even though the cooler is quite large, due to the height of the heatpipes we did not encounter any clearance issues in fitting the cooler to the DFI X58 nor the Asus P6T which both have large chipset heatsinks. Even with the fan fitted this did not interfere with the clearance of over sized memory heatsinks.
 heatsink clearence
In short a very good looking cooler which thus far has presented us with no issues that we can find fault with. I would have preferred to have seen the i7 kit included with the original unit but I guess this keeps the cost of the cooler down for those that have yet to make the upgrade leap.
Testing Methodology
I will be testing the OCZ Gladiator Max on an Intel Core i7 920 processor to assess the heatsinks ability to handle the heat-load of a quad-core. Whilst I appreciate that the OCZ Gladiator Max is also compatible with lower end CPU's, the Core i7 is renowned for being very toasty so should prove to be a very good test of the OCZ Gladiator Max's cooling capabilities.
Ambient temperature will be taken using a standard mercury thermometer and allowing it time to normalise. Processor idle/load and overclocked temperatures will be obtained using Real Temp 2.70 with the TJmax set to 100c, Each core temperature will be recorded. All testing will be conducted 3 times and an average taken to ensure the uniformity of results. All of the heatsinks were removed, and then re-installed a total of three times to ensure the elimination of any poor mounting issues. Arctic Silver 5 will be used on all of the coolers to eliminate the influences TIM may have on temperatures.
The program we will use to put the CPU under highest load will be IntelBurn Test ver 1.60 by AgentGod:
Linpack by Intel(R) is an extremely stressful program that will put even the most powerful X86/X64 CPU in the world at its knees. Load temp under Linpack will be up to 22*C higher than the competing software Prime95. This program will make usage of Linpack easier and more practical.
Ambient temperatures during testing ranged from 22.8 - 23.4 degrees Celsius.
Testing for noise is very subjective and without the correct decibel measuring equipment that is calibrated professionally including any results would be pointless. I will point out though that the OCZ is significantly quieter than both the stock Intel cooler and the Asus Triton that we reviewed previously. This is not really surprising as the Gladiator Max takes advantage of its bigger size by utilising a 120mm fan which turns at less revolutions than the 92mm fan of the Triton.
With the formalities out of the way let's crack on with the testing...
«Prev 1 2 3 4 5 Next»
02-02-2009, 08:35:05
premiumgfx
The Gladiator looks like a solid performer. Great review.Has anyone patented HDT technology? I've seen some Xigmatek CPU coolers which use it too.Quote
02-02-2009, 09:55:18
w3bbo
Xigmatek were the first to use it iirc.Quote
02-02-2009, 09:59:15
monkey7
Hmm direct heatpipe touch :') Any chance of comparing it with the noctua U12P 1366 or a TRUE w/ bolt thru?Quote
02-02-2009, 10:00:17
w3bbo
I have a Noctua sat next to me but it isn't a review item sadly.Quote
02-02-2009, 10:12:59
WC Annihilus
Wrong actually. First to use it were Zaward. It's just that Xigmatek was the one to take it and really run with it.
Looks like a solid cooler. Shame they didn't bring in the dimpled fin design of the Vendetta seriesQuote
