OrigenAE X10 HTPC Case
Specification
“The X10 is in essence the X11’s little sister. Given its pedigree, it has all of the style and the presence of its big brother but boasts a profile 20mm lower than that of its counterpart. However, this feisty temptress also has a full aluminium construct for efficient heat dispersion and sound damping, plus excellent hardware capabilities. The X10 enclosure is definitely for the discerning user who wants quality and power all contained within one aesthetically pleasing unit.”
– 8mm aluminium front face plate
– 2 x 60mm exhaust fan
– Front usb, audio and firewire ports
– Matched cd/dvd drive bezel
– Blue illuminated power button
– Vibration isolation grommets
– MCE compatible IR module
– Support for 1 hard drives
– Supports full sized components
– Enclosure dimensions: 435mm X 135mm X 452mm
– Construction materials: All aluminium chassis
– Mainboard support: ATX, Micro ATX
– PSU support: ATX PSU
– PCI / AGP card support: Full size
– Drive bays:
— 1 X 3.5″ internal drive bays
— 1 X 3.5″ external drive bay
— 1 X 5.25″ external drive bay
– Cooling system: 2 X 60mm rear exhaust fans
– Expansion slots: 7
– Front I/O ports:
– Net weight: 4.54kg
– Available colours: Black, Silver
I was surprised to see that the only cooling on the X10 was in the form of 2x60mm fans. This could possibly cause some heat issues on systems that run very hot (P4 for example). Many HTPC cases I’ve seen have 1x120mm fans in addition to 2x60mm fans – it would have been nice if OrigenAE could have incorporated this.
