Phanteks Eclipse P400 Review
Up Close: Â Interior Rear Side
There’s a lot going on back here, so pay attention. Â First up, cable management options are fairly decent, with a row of tie points featuring three of Phanteks proprietary hook and loop type fastenings. Â It does have to be said though, that to the right of this line there’s an absolute dearth of cable tie points so a bit of room for improvement there we think. Â You do though get a pair of 2.5″ brackets so you can stealth your SSDs
Â
The PSU has to be accessed from this side owing to the false floor, bu that’s no great shakes, to the rear of this there’s a cage which will hold 2×3.5″ drives. Â This is the cage that lies directly underneath the removable floor panel that will need to be removed if you want to fit a 360mm radiator.
Â
The cage is metal and the trays are plastic but feature nice tool free locking mechanisms on either side.
Â
There’s about 25mm of space to be had at the back, which should be plenty for anyone, just a shame Phanteks had the logo printed on their cable ties upside down, and no you can’t swap them round as they only screw in on the left. Â Attention to detail chaps!
 Â
