Phanteks Enthoo Evolv ATX Review
Accessories
Published: 10th September 2015 | Source: OCUK | Price: 139.99 @ OCUK |
Accessories
One of the joys of unboxing a case is seeing what goodies lie within the accessories box. Unfortunately for a great many manufacturers these days the accessories box consists of little more than a plastic bag cable tied to the interior of the case, or at best a small box clipped into one of the 3.5" bays. This is most certainly not the case with Phanteks, as their accessories box is packed to the gunnels with goodies. For starters you get a very nice glossy instruction book. Underneath this lies a sectioned plastic box containing, and more importantly separating all the screws and fittings you'll ever need for the build. Inside a separate plastic bag you get a slack handful of cable ties and a selection of Red, Green or White LEDs to place in the front of the case. As you can see in the pictures, there's a damn site more in her than meets the eye, but we'll get to that in a minute.
The instructions come in the form of a glossy well laid out pamphlet, with each area of the build separated enabling you to walk through the process or alternatively skip to the bit you're struggling with.
Inside the accessories box you also get three cantilever HDD brackets and a pump/reservoir bracket which benefits from a thick rubber coating to aid in minimising vibration and noise.
Is the front of the ATX version in the roof really free flowing? The mATX case has a plate behind some fins that stops air from moving forward and inevitably back into the intake fans; sensible but when things get toasty as this summer they definitely have, my case fans are screaming if I leave the roof on, definitely some restriction.
The offset looks much better in the ATX box in the roof, having a z97 gryphon in the mATX, the average sized vrm heatsink puts a stop to anything over a 35mm thick 280mm rad. I definitely love the amount of fan mounting slots they have included, you can easily shift fans and rads around in place to get the best final placement, just like those long slots on that rear 140mm fan mount, so much room to allow for tall things in the roof.
Awesome review, thanks for the in-depth coverage!Quote
