Phononic Hex 2.0 Peltier CPU Heatsink Review
The Build
Phononic Hex 2.0 Review
The Build
To mount the Hex 2.0 the first thing you have to do is pop off part of the plastic shroud that conceals the fan.  The reason for doing this is that you then need to remove the fan to access the screws which clamp the cooler down onto the CPU.
It isn't actually necessary to remove and unplug the fan to fit the cooler, as fitting can be accomplished with the fan still plugged in but hung to one side.  We have though taken it out to give you a peek at the PCB components that run the Peltier element of the cooler.
Although small, the Hex 2.0 is actually a bit of a pig to fit.  Actually that's not strictly speaking true, fitting the cooler is easy enough, getting the fan shroud to clip back on is the hard part as you have to simultaneously prod the fan in while trying to get the shroud in the right place and then clipped shut.  In the end we resorted to taking the GPU out so that at least we could see what we were doing.
Although the Hex 2.0 will invariably find a home in many SFF and HTPC cases, it's nice to see that it doesn't look out of place in a mid tower such as the CoolerMaster MasterCase5 we use as our test rig.
The last thing to mention before we head over to the testing is the Hex 2.0 Dashboard software associated with the cooler.  The software can be downloaded from the Phononics website and although the cooler can be run without it, it's the software that not only allows you to choose the colour and brightness of the Phononics LED logo, but also play with the cooling profiles.  There are in simple terms, three pre-programmed settings; Standard, Insane and High Ambient.  the forth setting "Smart Set", is essentially a custom set up option which after a calibration is carried out, allows the user to set a profile which determines the point at which the Peltier part of the cooler adds to the cooling provided by the fin stack and fan.  Activating this, and the "insane" mode, prompts a warning about the dangers of high ambient temperature, high humidity, and the potential dangers of condensation.  You have been warned.
«Prev 1 2 3 4 5 6 Next»
26-10-2016, 11:08:04
dwatterworth
As always thanks for the great investigation and presentation of data! I'd be interested in knowing what sort of power draw the different TEC modes incur. If the draw is high enough to really justify that PCIe supply, how does that affect the case temperatures?Quote
26-10-2016, 12:14:49
SuB
holy cow a pelt!? the 00's called, they want their watercooling back!
in all seriousness I'm gonna have a nose through this later, but hawt dayum, seeing a pelt brings back some memoriesQuote
26-10-2016, 14:10:59
Thelosouvlakia
I think that heatsink/material design has gone that far that for something like cpu cooling a peltier module would be considered obsolete...
Why waste more energy in cooling a cpu other than one/two fans spinning...
Pointless..Quote
26-10-2016, 14:37:07
MadShadow
While the idea is interesting I really don't see the purpose of a peltier here. Surely as it requires a fairly high amount of electricity to be powered, it is going to be producing heat energy as well. Perhaps that might be contributing to its not-so-great performance.Quote
26-10-2016, 18:23:12
SuB
I'd be interested to know the power draw on this. Back in my day you 100% could NOT power a pelt off-of a normal PSU, they would totally burn them out. if it is indeed manageable, I'd imagine it's not a very decent pelt and thus seems a bit pointless?Quote
