Prolima Tech Vortex Fan Review Round Up
Up Close 120mm
Prolima Tech Vortex fans
Up Close 120mm
The Vortex fans come packaged in nice simple part windowed boxes, showing the nature of theblades of the fan inside. The reverse of the box details product characteristics and a gives a brief technical specification.  Although fairly generic looking there is a general feel of quality to the vortex series.  I particularlyy like the Matt opaque finish to the blades of the non LED versions
Prolima Tech Vortex fans      Prolima Tech Vortex fans
The fan blades of the LED version on the 120mm Vortex are slightly opaque, again with a semi Matt finish to them.  Unlike the non LED version which has a solid black outer cowling, the LED version has a gloss smoked black outer cowling, presumably to better aid the dispersion of the light from the LEDs
The fans come to life when installed and working inside a case, with the 4 corner mounted LEDs giving a good spread of colour across the blades.
«Prev 1 2 3 4 5 Next»
25-01-2012, 11:25:19
Excalabur50
Those aluminium fans really look the goods nice to see something other than plastic get some good lighting on those and OMFG! Quote
25-01-2012, 14:02:30
badtaylorx
i wonder if a small (1cmx1cm) square of bitchathayne/dynamat/ice&water shield (stuck on the back of each blade) would kill the reverberation of the aluminum fan quieting it down???Quote
25-01-2012, 22:39:04
fredtrix
They do look very nice.Quote
