Raijintek Ereboss Black Review
Up Close: Packaging and Contents
This may well be the "Black" edition of the Raijintek Ereboss but the packaging still has plenty of Red and White going on and is certainly a classy piece of cardboard for a cooler that costs a mere £29.  Unlike the packaging of the Morpheus, where we were left wondering what the relevance of the aircraft carrier deck was, the Ereboss' box shows us details of the product inside as well as giving info on key features and technical specifications.
Raijintek Ereboss Black Review     Raijintek Ereboss Black Review
With the carton open we peer down inside and find a couple of bags of fittings, underneath which lies the cooler itself.
The instructions are multi language and are reasonably good, (ahem,not that we use them of course).  Along with mounting hardware for the vast majority of Intel and AMD sockets you also get eight rubber isolation fan mounts enabling, should you wish, a second fan to be mounted to the reverse side of the cooler.
«Prev 1 2 3 4 5 6 7 Next»
27-08-2014, 06:34:18
Robi_G
£30 savings over the darkrock is worth a bit of a fiddle, you could buy a long screwdriver and a decent fan and get change from that.Quote
27-08-2014, 11:05:57
sonsonate
Looks a lot like the HR-02/HR-02 Macho.Quote
27-08-2014, 12:21:40
Wraith
Pretty poor work on the fan mounting but given its size I'd say it'll be a good option for passive cooling.Quote
27-08-2014, 12:39:35
shambles1980
I hate those stupid rubber fan mounts. I prefer the metal spring clips to be honest. (mounting and re mounting never seems to be as easy with the rubber ones) still if it performs well its definitely a better option than the lower end aio's "imo" and at £30 its a really good price. cant see much wrong with it to be honest. personal id change to a 120mm fan probably wouldn't worry that much about the static pressure as the fins don't really look like they are that close together soid probably aim for a CFM focused fan with lower rpm, Then stick them in push pull. id imagine you could get the system acceptably cool with lower noise levels like that.Quote
