Raijintek Morpheus GPU Cooler Review
Up Close: Packaging and Contents
Raijintek Morpheus Review
The Morpheus comes boxed with very little in the way of internal protection, that said, our review sample arrived in perfect condition.  We're not entirely sure as to the relevance of the image of an aircraft carrier to the job in hand or the name Morpheus, but at least it looks manly and impressive.
Raijintek Morpheus Review     Raijintek Morpheus Review
With everything carefully removed from the box we bigin to sift our way through the contents.  And boy is there a lot to sift through.  Along with the main cooler Raijintek also supply a great selection of small Aluminium heatsinks designed to be attached to the RAM on the chosen board.  You also get a more than generous helping of double sided adhesive tabs.  Enough we think to do the job twice.  There's also a larger single piece heatsink designed for the VRMs and again more than enough TIM putty to enable this to be done a few times.  Also included in the pack is a small pack of conventional TIM along with Spring clips for 120mm fans, all the screws you'll need and a  universal fitting bracket.
The Raijintek fans we used for the review didn't come inside the box are not supplied with the cooler at the point of purchase.  This might seem a little bit stingy however it does leave you free to select your own, or use fans you already have to keep the cost down.  The final item in the box is the sheet of fold out multi language instructions.
«Prev 1 2 3 4 5 6 Next»
13-05-2014, 05:44:56
WYP
Some very nice temps there, but i must say that thing is massive.
How many slots does that thing occupy? 4.... 5?
That being said it does deliver a cooling experience which is only beaten by a water cooler.Quote
13-05-2014, 05:46:54
tinytomlogan
The fans alone are a slot though really.......Quote
13-05-2014, 05:51:12
barnsley
I guess you could get some low profile fans to lower the overal size. Very impressive temperatures. It shows how much AMD messed up with the stock cooler.Quote
13-05-2014, 05:52:19
tinytomlogan
Most people only runa single GPU and maybe at worst a soundcard so there isnt much need. It only rules out dual cards and slim fans wouldnt fix that....Quote
13-05-2014, 05:56:01
barnsley
It'd give it a less bulky profile though, no? It might look a bit better with thinner fans. Just my feeling on the matter :P. I just like the shape of the cooler and I think the fans kind of distract from the overall lines.Quote
