Raijintek Morpheus GPU Cooler Review
Up Close:Â The Cooler
The Morpheus is vey similar in many respects to a slim line top down CPU cooler, with the exception that it is considerably longer. Twelve 6mm heat pipes originate from either side of the contact plate and make their way evenly spaced up through and along the 129 element Aluminium fin stack.Â
Â
The pipes are split into two groups of six with each group catering for their respecitive halves of the stack. It has to be said that the Morpheus bears more than just a passing resemblance to the Alpenfohn Peter in both its measurements and design.Â
Â
The contact plate of the Morpheus is finished so as to be mirror smooth , with the whole assembly exuding an air of quality that we weren’t really expecting. It appears QA is high on Raijintek’s list of priorities.
