Raijintek Styx Aluminium MATX Case Review
Published: 22nd October 2015 | Source: Raijintek | Price: £64.99 @ OCUK |
Having reviewed the Metis a little while back, and been largely delighted with it, we were more than a little bit chuffed to see the bigger Styx appear at OC3D towers. Being that bit bigger the Styx can house M-ATX boards as well as the smaller M-ITX units. It can also accept a decent sized GPU as well as having storage for up to 3 HDDs and numerous SSDs in various configurations. It's also available in a range of six colours, all hair silk anodised onto sheet Aluminium. What we have then is the makings of a Prodigy killer. Let's just hope they haven't overlooked anything too obvious, you know, like decent water cooling capabilities.
Dimensions | 210x360x335mm (DxWxH) |
Materials | 1.5mmAluminium panels on 0.5mm SPCC |
Motherboard Support | M-ATX, M-ITX |
Colours | Black, Silver, Red, Blue, Gold, Green |
Weight | 3.8kg |
5.25" | 1 9Slim) |
3.5" | 3 |
2.5" | Up to 4 (some shared with HDD) |
Expansion slots | 5 |
Front I/O | USB 3.0 x2 HD Audio |
Cooling | Rear: 1x120mm (Installed) Roof: 2x120mm (1x240mm rad) Base: 1x120mm |
Max GPU Length | 280mm |
Max CPU Height | 180mm |
Key Features
Aluminium colour hair-silk anodized appearance design
Internal coated black throughout
Compatible with ATX POWER SUPPLY
Compatible with max. 280mm VGA card
Supports up to max. 180mm height CPU cooler
2* USB3.0 ports
Anti-vibration rubber for HDD installation
Supports 3* 3.5"HDD +2*2.5"HDD/ 1* 3.5"HDD +4*2.5"HDD
120 mm performance fan pre-installed at rear
Option to install 240mm radiator on the top/side and 120mm fan at bottom
Large zone of ventilated holes for airflow on side panel
Someone needs to mod a proper, full size acrylic window into that case. That would look epic. Maybe a project for ColdZero...
Please use multi-quote
Follow the link in the review to the OCUK.Quote
