Raijintek Styx Aluminium MATX Case Review
Up Close: Exterior Rear and Base
Raijintek Styx Review
Round the back things are pretty non standard.  For starters, the IEC mains connection is right at the top, which is a bit of an odd place to be honest.  Down on the deck near the bottom of the case would have made much more sense.  You do though get a sensible five PCI slots, beneath which there's a 120mm fan on extract.
Raijintek Styx Review     Raijintek Styx Review
The PSU is mounted with what would traditionally be its rear, pointing directly down though the large aperture on the left hand side of the base, which is actually the front of the case.  beside this there's a vent for a 120mm fan and alongside that the off side of a 3.5" drive mount.  The case itself sits on four triangular solid rubber feet which are screwed into the Aluminium.
«Prev 1 2 3 4 5 6 7 Next»
22-10-2015, 06:26:57
Oseth
I wonder what the green one looks like, what type of green is it?Quote
22-10-2015, 06:34:31
tinytomlogan
You ask like we have every single colour to hand lolQuote
22-10-2015, 06:35:45
MadShadow
Someone needs to mod a proper, full size acrylic window into that case. That would look epic. Maybe a project for ColdZero...Quote
22-10-2015, 06:48:30
Feronix
I do quite like what Raijintek are doing, although this case is just a bigger version of the Metis, immediately making it look like a Prodigy M ripoff and I hated that case Quote
22-10-2015, 07:04:31
G-Dubs
If you did, all you'd see was the side of the PSU and a dirty great HDD rack.
Please use multi-quote
Follow the link in the review to the OCUK.Quote
