Raijintek Styx Aluminium MATX Case Review
The Build
Raijintek Styx Review
The Build
A single fold out sheet of instructions and a bag of screws with a few cable ties and a buzzer is all you get by way of instructions and accessories, but hey, there's enough and that's all that matters right.
Raijintek Styx Review     Raijintek Styx Review
Fitting the PSU is a lot easier than it might look.  We found the best way to do this was to tip the case on its side.  having fed all the cables through to the back though we later discovered it's actually easier to keep them front side.
With the Motherboard in you start to get an idea of just how tight it is in there.  Take a look at where the ATX socket is relative to the PSU!  Theoretically you can get a 3.5" drive mounted on the floor, but as there's no where to run the cables and actually no room under the 8 pin CPU cable we found it impossible to do so.  Nice in theory, bad in practice.
«Prev 1 2 3 4 5 6 7 Next»
22-10-2015, 06:26:57
Oseth
I wonder what the green one looks like, what type of green is it?Quote
22-10-2015, 06:34:31
tinytomlogan
You ask like we have every single colour to hand lolQuote
22-10-2015, 06:35:45
MadShadow
Someone needs to mod a proper, full size acrylic window into that case. That would look epic. Maybe a project for ColdZero...Quote
22-10-2015, 06:48:30
Feronix
I do quite like what Raijintek are doing, although this case is just a bigger version of the Metis, immediately making it look like a Prodigy M ripoff and I hated that case Quote
22-10-2015, 07:04:31
G-Dubs
If you did, all you'd see was the side of the PSU and a dirty great HDD rack.
Please use multi-quote
Follow the link in the review to the OCUK.Quote
