Raijintek Triton Review
Performance and Testing
The test set up consisted of the following
Intel i7 3960X [email protected] 1.1v (undervolted) 4.0GHz @ 1.25v 4.4GHz @ 1.35v 4.6GHz @ 1.45v Gigabyte X79 UD3 Corsair Vengeance LP Memory Corsair HX850 V2 Corsair Force GT 60GB Coolermaster Storm Trooper.
As usual we'll be testing our coolers at varying  levels of overclock and increasing levels of voltage.  this in turn of course means increasing levels of heat which the coolers need to dissipate.  To begin with we start with the undervolted stock speed.  Why undervolted? well if you have things set on "Auto", you may well be using more volts than are actually required to run at the chosen frequency, for example our 3960s will run quite happily at just 1.1volts, solid as a rock, 24/7, and as such we use this as our starting point.
Continuity is very important in testing, and for this reason we keep as many of the potential variables as locked down as possible.  We will be using OCCT in Linpack X64, AVX compatible with all logical cores tested and 90% free memory utilised. The test is set up to run automatically with just a few clicks to set it going.  A 10 minute idle followed by 30 minutes of testing and a 5 minute cool down is the order of the day and brings the total test time per clock speed to 45 minutes.  So as to remove subjectivity in determining whether a CPU has failed, OCCT is set to stop the test and register a fail should the max temp exceed 80 degrees.  In testing we noted that if even just one of the cores exceeds 82 degrees OCCT halts the test and a fail is recorded.
The Triton doesn't ship with any fancy pants control and monitoring software, but there is a small rheostat speed control attached to the fans, so we used this to set three speeds.  The High setting was just that, fill tilt at 12 volts as always.  For the Medium we stopped the fans down a bit to about half way, a level roughly equivalent noise wise to the balanced setting we use on other systems.  For the "low we wound the dial all the way to its other end stop.  At this level the fans were essentially silent so much so that we could now hear a faint hum from the pump.
From the results it would appear that at the High setting the Triton holds it's own, with the Medium and low coming way down the graph.
Turning now to the 4GHz test we up the voltage to 1.25 volts, this is what is deemed normally as stock volts. Something we are always harping on about on the forums is AUTO does not mean stock volts, and normally if you overclocking with "auto" volts the motherboard will be upping the volts much more than needed if you were to do it manually. By whichever means it happens, upping the volts (especially from our 1.1v undervolt) does have a big impact on temps, with an average increase of 10-15 degrees seen in the results.
At the higher levels of heat generated by the increase in voltage required for the 4.0GHz overclock, fan performance, although still a factor becomes less critical, replaced instead by a coolers ability to conduct the heat up the heat pipes and more crucially the total surface area of the fins enabling convection to the atmosphere.  In the case of AIOs and water cooling the surface area of the radiator and the efficiency of the contact plate begin to play more of a factor.
At high settings the Triton is again up there challenging the big boys.  Very impressive performance indeed.
Upping the volts still further we achieve a stable 4.4GHz overclock at 1.35 Volts. It's here we start to separate the wheat from the chaff, with lesser coolers not able to disperse the increased heat effectively. Again we see a jump of 10 degrees or so from the figures at 4GHz. Both the H100 and the well-respected D14 are creeping into the 70s here, indicating that only the cream of the crop will excel at this level.
This is where we start to separate the men from the boys.  The Triton has slipped a bit but is still in the top five.  Best we don't look at the Medium and low setting scores as they're quite frankly embarrassing.
Finally our 4.6GHz test. Don't be fooled, this is an extreme test and the graph reflects this, you will only see the very best featured in this graph.
If we really want to measure outright performance, this is where we do it.  Most consumer systems don't generate anything like the heat of 2011 so if it works here it'll work anywhere.  As suspected, the Medium and high fan settings have seen the Triton slide off the bottom, but at high fans it's still representing itself well. being only 3.6 degrees off the mighty 110i GT and just pipping the H105
«Prev 1 2 3 4 5 6 7 8 Next»
20-02-2015, 16:35:49
barnsley
Excluding the quality issues that some people have had with them I really quite want to get my hands on one, albeit only for the pump.
Pump+(green)acrylic tubing+ 120mm rad (because thats the only one I can fit) and you've got a great looking AIO. Albeit the single most expensive 120mm AIO ever made..Quote
20-02-2015, 16:39:36
boulard83
Nothing about the use of an aluminium radiator with copper block ? Galvanic corrosion will occur, NM the anti corrosion liquid aditive it will occur over time.Quote
20-02-2015, 16:49:26
tinytomlogan
Common misconception with modern coolants it wont happen - they would need to be touching and even then its very rare with the modern additives.Quote
20-02-2015, 18:19:03
Thelosouvlakia
I'll get this plus a pair of NFF-12s and hopefully the 8350 will remain cool enoughQuote
20-02-2015, 18:35:11
daletur328
Seems like a good option,with a fan change, for some of the stupidly small cases that are appearing.Quote
