Scythe Ninja Mini CPU Cooler
Installation of the Scythe Ninja Mini CPU Cooler was a little fiddly due to the cooling fins of the heat sink protruding out past the push/lock mounting on the base. Even with the assistance of a removable motherboard tray I found it awkward to get to the push/lock pins attached properly on the motherboard back-plane side.
You can see from the above images that the Scythe Ninja Mini CPU Cooler had no compatibility issues with my ASUS P5B Deluxe wi-fi/App motherboard. The heat sink provides more than ample clearance from capacitors and the heat-pipe cooling solution around the motherboards voltage regulation area.
Scythe Ninja Mini installed
With the fan situated on the left hand side of the heatsink the included 80mm fan comes very close to touching the top of my RAM, but thanks to square shape of the heat sink there are another 3 sides that you can install it on.
Scythe Ninja Mini almost touching RAM
Scythe Ninja Mini showing RAM
Other than the included fan and installation clips residing so close to my RAM, there were no other issues to report. The Scythe Ninja Mini looks quite at home in my case.
Now that we've had a thorough look at the Scythe Ninja Mini CPU Cooler let's head over the page to see how we're going to test it...
«Prev 1 2 3 4 5 6 Next»
04-12-2007, 06:02:25
Seems to have more than a few references to Scythe Kama Cross rather than Mini Ninja (I guess cut'n'past review format) incl. the award "Today I have decided to award the Scythe Kama Cross CPU cooler Overclock3D's "Recommended' award for its performance in todays review." Quote
04-12-2007, 06:09:49
Woops my apologies...fixed :iamwithstQuote
04-12-2007, 07:54:57
i have one of those too!
lovly piece of kit, and i've fitted it in a HTPC too
and for anyone wanting to get one but think you might cut your fingers into million pieces.
you simply dont place your fingers where the push pins are, get a flat head screw driver, go from the top of the cooler, on all 4 corners there is a slot on those fins where you can see the push pin from the top.
on those push pins, theres a groove on top, simply use flat head screw driver, push it down till 'click', job done.
same as for unlocking the pin to remove, use flat head screw driver, twist it, and pull off.
pic of it fitted inside a HTPC (excues the 'cable managment')
04-12-2007, 08:07:04
What the fudge ! weihk u just scared the heck out of me with the cableness !
Don`t like 775 twisty clip in thingies >.<
Anywho, nice review m8, looks like a great choice for htpc or even a regular pc if u`r scared of heights.
Don`t personally like the price, I think Scythe products are overpriced in the UK in general tho. Imo.
Took a note of the 775 retention bracket, and I notice they`ve stripped the curves from the central section. This is a good thing, I`ve just had to hack a section away on one due to caps.Quote
04-12-2007, 10:21:27
Mr. Smith
Nice job fella, well written as usual
One thing though, I really think graphs should start from zero (the noise level graph), I find those styles of graphs to be misleading at first glance. Often people see a graph; higher is better 'woah, that one is loads better' when in reality the difference is small.
Obvously this is my personal opinion, not sure how other people feel but whenever I see this type of graph used on review sites I instantly become suspicous, as if the site was trying to mislead the reader (not that you would ever do that mate).Quote
