Scythe Ultra Kaze 120mm Fans
Published: 8th December 2007 | Source: Scythe-EU | Price: US$12.00 |
Scythe are a name synonymous with aftermarket cooling enhancement products. I would like to wager that there aren't too many PC enthusiasts who hadn't at least seen, owned or heard about this well known Japanese based company's products. But who are Scythe, and what do they do?
Today I have been given the opportunity of reviewing Scythe's latest product: the Scythe Ultra Kaze 120mm Fan/s. Only recently released, the fans promise more air flow and an increase in static pressure which should make these the perfect candidates for heat sink and radiator cooling duties.
The Scythe Ultra Kaze range of 120mm fans are available in 3 different flavours: 1000 RPM, 2000 RPM and 3000 RPM versions.
Will these be the next 'must have' item on the air cooling and water-cooling enthusiasts shopping list? Well follow with me as we seek to answer that very question. Let's make a start by looking at the Ultra Kaze' specifications.
Specifications
The specifications for the Scythe Ultra Kaze range have been taken directly from the Scythe-EU Product Page
The Scythe Ultra Kaze' range certainly looks very good on paper. However, the MTBF estimation is extremely low even for a bearing fan. Scythe's Minebea range of cooling fans utilised bearings and had a MTBF of some 160,000 hours. Big difference!
Anyway let's head over the page to see what all the fuss is about...
Scythe Co., Ltd., began its operation and business in November, 2002 as a distributor and manufacture of PC parts & gaming devices for “DIY PC Experts!”. Scythe’s first venture was to manufacture a super powerful YET super quiet CPU cooler (Scythe Kamakaze CPU cooler), and with the great success of this Kamakaze CPU cooler, Scythe became recognized as the leading CPU cooler supplier in Japan’s Akihabara Electric Town. Shortly there after, due to popular demand, Scythe began exporting products all over the world.
Specifications
Model name:
Kaze 120mm (1000rpm/2000rpm/3000rpm)
Model:
DFS123812L-1000 (1000rpm Version) DFS123812L-1000 (1000rpm version)
DFS123812L-2000 (2000rpm Version) DFS123812L-2000 (2000rpm version)
DFS123812H-3000 (3000rpm Version) DFS123812H-3000 (3000rpm version)
Manufacturer: Scythe Co., Ltd. Japan Scythe Co., Ltd.. Japan
Measurements: 120 x 120 x 38mm (HxBxT) 120 x 120 x 38mm (HxWxD)
Specifications:
19,81dBA / 44,44CFM / DC12V / 0,25A (1000rpm Version) 19.81 dBA / 44.44 CFM / DC12V / 0.25 A (1000rpm version)
32,91dBA / 87,63CFM / DC12V / 0,25A (2000rpm Version) 32.91 dBA / 87.63 CFM / DC12V / 0.25 A (2000rpm version)
45,90dBA / 133,60CFM / DC12V / 0,60A (3000rpm Version) 45.90 dBA / 133.60 CFM / DC12V / 0.60 A (3000rpm version)
Weight: 225g
Connection: 3-pin (4-pin adapter is attached)
Cable length: 30cm
Storage: Bearings
MTBF: 30,000 hours
Model:
Specifications:
Weight: 225g
Cable length: 30cm
Storage: Bearings
MTBF: 30,000 hours
Awesome detailed review Peevs. Looks like they're a winnerQuote
Thanks Kemp I'm glad you liked it.Quote
OOOOOOoooooooo
nice review, well done.
if i get a much bigger case for me next build, i'll consider these fans instead of the thinner S-Flex.Quote
Very sweet fans, great review Matt as usual!!! Looks like I know which fans I'll be using for my next build.
I bet those Ultra 3000's in push/pull around a triple 120mm rad would be amazing.Quote
Thanks weihk and Fraggles.
@ FragTek: Yeah those Ultra 3000 would work perfectly in a push/pull config. Just make sure you run them at 7v though aight
Quote
