SilenX Ixtrema 80 & 120 Quiet Fans
Specification
Published: 28th May 2006 | Source: SilenX | Price: |
Specifications
Specifications taken directly from the SilenX website:
"Featuring the first fan blade designed for optimal airflow and aerodynamics, SilenX iXtrema Pro Series Quiet Fans are the result of thousands of hours of testing and fluid dynamics simulations. The result is a fan that can push more air per revolution at lower noise levels than any other fan available and proof that SilenX delivers the best in silent computing. Reduced motor size, increase fan blade surface, lower lateral surface area on the motor vanes along with silicon-composite fan mounts puts this fan above the rest."
80mm Ixtrema
120mm Ixtrema
80mm Ixtrema
120mm Ixtrema
nicely done man
Quote
Please note that Page #1 currently has problems. I'm just performing a restore from Sunday's backups
Quote
O wow, it's even worse than it was before...
Quote
Review is taken down while XMS repairs the reviewQuote
FixedQuote
