SilenX Ixtrema 80 & 120 Quiet Fans
Appearance
Appearance
Painted in colour I can only describe as gun-metal, and with the looks of a Jet engine the Ixtrema fans look like they mean business.
Ixtrema 80mm Ixtrema 120mm
Ixtrema 80mm & 120mm
Each fan comes with a 3-pin fan cable, which is capable of sending fan speed information to your motherboard. Also included in the pack is a 3pin to 4pin converter, 4 standard fan screws and 4 rubber fan plugs that can be used in place of the screws to dampen vibrations.
80mm In Case
Unfortunately my Silverstone TJ05 didn't have any space for an 80mm fan, so I thought it might be a good idea to put the fan to use on my heavily overclocked G.Skill memory, which was hitting 44oc and giving me a few stability issues. After a bit of messing around, I found some screws long enough to bolt it on to the holes in my Swiftech waterblock. The Ixtrema made an amazing difference to the temperature, as you can see on the next page.
120mm Installed
120mm Installed 120mm Installed
As you can see from the pictures above, the 120mm Ixtrema could easily be installed using the standard fan screws, however, in order to use the vibration dampening plugs I was required to remove the fan grill as the plugs were too short.
«Prev 1 2 3 4 5 Next»
30-05-2006, 11:15:59
WC Annihilus
nicely done man Quote
30-05-2006, 11:28:36
JN
Please note that Page #1 currently has problems. I'm just performing a restore from Sunday's backups Quote
30-05-2006, 11:30:32
WC Annihilus
O wow, it's even worse than it was before... Quote
30-05-2006, 11:44:57
FarFarAway
Review is taken down while XMS repairs the reviewQuote
30-05-2006, 13:11:38
JN
FixedQuote
