SilverStone FN and FW Series fans Review
Never one to hang about Silverstone have added to their already extensive range of fans by augmenting the FW and FN series.  Here we're going to take a look at the FW121, the FW122 and the FN123.  Although they might be numbered concurrently, there are significant differences between them.  In simple terms the FW121 is a slim PWM fan with white blades and a blue cowling, the FW122 is a standard thickness PWM fan with white blades and a blue cowling and the FN123 is a slim non PWM fan with White blades and a Black cowling.  With us so far?  No?  Then best we have a look at the full technical Specification.
FW121
Model No.
SST-FW121
Color
White fan blades, blue frame
Bearing
Long life sleeve
Connectors
4pin PWM
Rated Voltage
12V DC
Start Voltage
5V DC
Rated Current
0.02 ~ 0.09A
Rated Power
0.24 ~ 1.08W
Speed
800 ~ 2000 rpm
Airflow
13.1 ~ 32.6CFM
Static Pressure
0.31 ~ 1.52mmH2O
Noise Level
14.7 ~ 24.6dBA
Life Time
40,000 hr
Dimension
120mm (L) x 120mm (W) x 15mm (H)
Weight
109g
FW122
Model No.
SST-FW122
Color
Bearing
Long life sleeve
Connectors
4pin PWM
Rated Voltage
12V DC
Start Voltage
5V DC
Rated Current
0.07 ~ 0.19A
Rated Power
0.84 ~ 2.28W
Speed
1000 ~ 1800 rpm
Airflow
42.6 ~ 76.5CFM
Static Pressure
0.31 ~ 1.52mmH2O
Noise Level
18.4 ~ 28.1dBA
Life Time
40,000 hr
Dimension
120mm (L) x 120mm (W) x 25mm (H)
Weight
130g
FN123
Model No.
SST-FN123
Color
White fan blades, black frame
Bearing
Long life sleeve
Connectors
3pin
Rated Voltage
12V DC
Start Voltage
5V DC
Rated Current
0.16A
Rated Power
1.92W
Speed
2000 rpm
Airflow
32.6CFM
Static Pressure
1.52mmH2O
Noise Level
23.5dBA
Life Time
40,000 hr
Dimension
Weight
112g
«Prev 1 2 3 Next»
01-10-2014, 18:28:25
realneil
These fans are good looking, and SilverStone stuff is top notch too.Quote
02-10-2014, 01:18:39
LangZone
These are some nice FN fans.Quote
02-10-2014, 09:09:07
shambles1980
I havent had the best of luck with sleeve bearings. i much prefer ball. hope they do the 15mm in ball and i would happily buy 6 of them.
also 1 of the 2 fans that came with my tundra 03 failes incredibly quickly (i say failed i mean started make a horrible noise so i couldnt use it any more.)
but performance wise they work perfectly adequatlyQuote
