Silverstone Fortress FT04 Review
The Build
Published: 3rd February 2014 | Source: Silverstone | Price: £174 |
The Build
Aside from very comprehensive instructions Silverstone also include a glossy brochure detailing all their products, you know, for the times when your internet is broken and you have to go "analogue". You also get a box packed with accessories, brackets, cable ties and the usual screws.
It's not strictly speaking necessary to remove the motherboard tray to fit the motherboard, but you know, "When in Rome" and all that. In reality it does make fitting easier, and if you're planning a water-cooled rig it will be much easier to attach the various blocks and barbs in this manner.
The motherboard tray slides in easily from the reverse side and is held in place by three screws (one of which took us a while to find). The expansion slots don't have thumb bolt retainers, so again you're going to need your trusty screwdriver. Thankfully Silverstone have thought to cut some holes in the sides to enable your driver to line up with the screw heads.
We said it was a tight fit for the PSU didn't we. Tighter than a Nuns Nacho in fact. We've mounted the PSU with the fan up as owing to the layout of the cables on the rear this gives us that little bit more length to play with.
Will read later mate, looks huge, was hoping it'd be a nice small case!
I'm also really not liking the motherboard orientation. The 90 degree roll was what made these things special.Quote
