SilverStone Primera PM01 Review
They say first impressions count, and if that’s the case then the the new Primera From SilverStone is off to a racing start.  Finished in high gloss black or white and with styling cues taken from luxury sports car design the Primera certainly seems to have a bit of va-va voom about it.  But style is nothing without substance, so the Primera will still have to have it where it counts, and what better way to to see whether this is a racer or a wreck than to have a quick gander at the vital statistics.
Technical Specification
Dimensions 571x220x560mm (HxWxD
Material Steel and Plastic
Weight 9kg
Motherboard Support ATX, M-ATX
Expansion bays 7
2.5″ 5 dedicated, 4 shared with 3.5″
3.5″ 4 (shared with 2.5″)
5.25″ 0
Air Cooling
Front:  3x140mm (3x120mm optional)
Roof:   3x120mm 0r 140mm optional
Rear:   1x140mm (120mm optional)
Water Cooling
Front:  Up to 280mm or 360mm
Roof:   Up to 280mm or 360mm
Rear:   120mm or 140mm
Front I/O USB2.0x2, USB3.0x2, Audio, Lighting control.
Max CPU height 180mm
Max GPU length 16.5″
Max PSU length 240mm
Key Features
Includes three 140mm LED fans and built-in LED strips for stunning visual impact
Oversized front panel mesh design inspired by supercar intake grill
Support two 240/280/360mm radiator for AIO liquid cooler or custom water cooling
Reserved water tank mounting holes for water cooling setup
Removable filters with positive air pressure design for dust reduction
Built-in 4-segment LED light controller to adjustable brightness and modes
Super clean internal look with PSU and drive bay cover
Includes 10 in 1 fan hub for fan cable management
Â
