SilverStone Tundra TD02-E AIO Review
Up Close: Packaging and Contents
The TD02-E comes in a fresh looking Blue and white box.  Along with higher gloss images of the cooler within.  The box also displays details and key features of the product.
SilverStone Tundra TD02-E     SilverStone Tundra TD02-E
SilverStone are using the same egg box card packaging as pretty much every other AIO we've seen, but who cares, it saves the planet and it does the job
Along with the excellent pictorial multi language instructions you also get a bag of fixings.  Aluminium AMD mounting brackets are included (the Intel ones come pre fitted but can be removed and swapped for the AMD ones), and there's also a back plate, a molex adapter and a fan splitter cable
The white bladed fans will spin between 1500 and 2500 RPM outputting 92.5CFM of air at a static pressure of 3.5mmH2O.  From a noise perspective the speed range will see you with a max and minimum of 18 and 35dB(A) respectively.
«Prev 1 2 3 4 5 6 7 Next»
16-04-2015, 09:19:37
You_What?
Damn it, got to replace my TD02 now.Quote
16-04-2015, 09:57:53
AlienALX
Nice.
Nowhere near as pretty as the last one though.Quote
16-04-2015, 10:13:30
You_What?
Originally Posted by Vault-Tec View Post
Nice.
On second looks, you're right.
I knew something didn't look as good as the one I've got, its the radiator. Quote
16-04-2015, 10:21:31
AlienALX
Yeah that one is absolutely frigging gorgeous. On this one the rad just looks like a boggy stock one.
They've taken the alu top off too, price no doubt. The last one was quite expensive and wasn't uber performance wise but god damn it looked good.Quote
16-04-2015, 12:00:40
shambles1980
i was not overly impressed with the tundra i had. which made me get back in to custom loop water cooling.
Having said that it did cool the system. it just could not stand up to an overclocked IBT run.
And i some how doubt many if any AIO's could.
I also see they have widened the tubing compared to mine so that should be a plus.
also i dont see if it says they used copper or aluminium rad, the one i had was aluminium which would contribute to slightly worse heat dissipation.Quote
