SilverStone Tundra TD02-E AIO Review
Assembly
Assembly
The TD02-E follows the well trodden path of attaching stand off mounting hardware to a back plate, or in the case of the 2011 rig we use, directly to the Motherboard.  The cold plate, with it's attached black anodised Aluminium brackets is then slid over the top before being screwed down by spring tensioned bolts.
SilverStone Tundra TD02-E     SilverStone Tundra TD02-E
The top of the cold plate is gloss black and displays the SilverStone logo which illuminates Blue when the pump is running
The TD02-E fits easily into the roof of our Cooler Master Test Trooper, with the changed angle of the light revealing what appears to be a carbon fibre effect on the sides of the radiator under the acrylic panels.  This effect isn't something that's immediately obvious to the eye, so if intended by SilverStone as a style feature it does perhaps need to be a bit more prominent.
«Prev 1 2 3 4 5 6 7 Next»
16-04-2015, 09:19:37
You_What?
Damn it, got to replace my TD02 now.Quote
16-04-2015, 09:57:53
AlienALX
Nice.
Nowhere near as pretty as the last one though.Quote
16-04-2015, 10:13:30
You_What?
Originally Posted by Vault-Tec View Post
Nice.
On second looks, you're right.
I knew something didn't look as good as the one I've got, its the radiator. Quote
16-04-2015, 10:21:31
AlienALX
Yeah that one is absolutely frigging gorgeous. On this one the rad just looks like a boggy stock one.
They've taken the alu top off too, price no doubt. The last one was quite expensive and wasn't uber performance wise but god damn it looked good.Quote
16-04-2015, 12:00:40
shambles1980
i was not overly impressed with the tundra i had. which made me get back in to custom loop water cooling.
Having said that it did cool the system. it just could not stand up to an overclocked IBT run.
And i some how doubt many if any AIO's could.
I also see they have widened the tubing compared to mine so that should be a plus.
also i dont see if it says they used copper or aluminium rad, the one i had was aluminium which would contribute to slightly worse heat dissipation.Quote
