SilverStone Tundra TD02 LITE Review
Fitting
SilverStone Tundra TD02-LITE Review
Fitting
As usual we're using our sizzling 2011 set up, so we can dispense with the back plate.  Fitting though, whichever CPU you favour is a piece of piddle.  Having secured the radiator in your chosen location, the next job is to thread in the mounting pins.  In our case these screw into the mobo direct, in all other instances pins are passed through from behind.
SilverStone Tundra TD02-LITE Review     SilverStone Tundra TD02-LITE Review
The pump assembly is than placed over the top and held down with spring tensioned screws.  It really doesn't get much simpler than that.
The LITE looks quite at home in our Cooler Master "Test Trooper" case, with the white bladed monochromatic fans adding a little touch of extra class we think, and even though the curves are tight, the tubing shows no signs of kinking.
The top of the pump lights up with a subtle blue LED light.  The light doesn't completely engulf the logo, instead limiting itself to the central part of each of the sides of the hexagon
«Prev 1 2 3 4 5 6 Next»
28-07-2015, 14:15:53
Wraith
70 notes for a 240mm AIO that's stonking billy bargain stuffs, the unit itself looks very similar to the old Corsair H100, the hoses, block & fittings, it's quite the performer for the money too. And a huge plus 1 for the packaging I have a soft spot for that eco friendly boxing.Quote
