Sunbeamtech Acrylic HTPC Case
Test Results
Test Results
Cooling Performance
The Sunbeamtech Acrylic HTPC Case performed very well in our cooling performance testing. The case breathes very well, and provides very good cooling to all major areas, which is impressive considering that 3 x 80mm fans handle the intake and exhaust duties.
Thermal Zone Idle Temperatures
Thermal Zone Load Temperatures
Noise
The 80mm fans that the Sunbeamtech Acrylic HTPC Case come with are certainly competent coolers, and provide excellent airflow which we can see from the above graphs. However, they aren't as quiet as you would expect. The supplied 80mm fans produce a very low frequency hum that is quite audible, and which could become an issue for those who prefer silence, or as near to it as possible. Once again, if you find the fans too noisy for your particular taste you could always swap them over.
«Prev 1 2 3 4 5 6 7 Next»
