Thermalright HR-07 Trio Heatpipe Coolers
Packaging & Appearance
Because of the close proximity of the memory modules on i7 motherboards, Thermalright recommend both the Type H (High) and Type L (low) profile kits so that both kits can be used in unison with one another. Here, we look at each kit in greater detail:
The packaging the Ram cooler arrives in is a standard Thermalright affair with a plain brown cardboard box, printed with the Thermalright logo and product name on the front with a small window cutout displaying the cooler inside. The rear of the box  features much the same but this time including the product specification.
front box box rear
Opening the box up we are a greeted with the coolers themselves which are held tightly in place by means of moulded Styrofoam. Also included in the box are 6 full length thermal pads complete with removable backing. A large sticker and an easy to follow instruction leaflet are also included.
pads instructions
The Type H variant of the Ram cooler is unsurprising the highest of the two kits, standing 60.37mm high (almost 2.5" for those still working with imperial measurements). Two nickel plated copper heatpipes attach the finned array to the ram cooler plates ensuring super efficient thermal transfer from the plates to the outside air with minimal fuss.
cooler 1 cooler 2
The base plates are very thin yet sturdy enough not to bend accidentally and because the heatpipes are flattened to the plates on both sides, the ram cooler should not foul any module sitting along side. The main fin array may however cause difficulties in this area, something I will investigate later in the review in the test setup area.
cooler base cooler perspective
The Type L kit is packaged in near identical format to the Type H above. Despite the large 'TYPE L' font, I initially thought I had been sent two lots of the same kit. I even chastised the editor, calling his and indeed Thermalrights intelligence into question. It wasn't until I opened the kit up that I realised that the two kits were in fact slightly different and labelled as such on the outside of the boxes. Needless to say I ate humble pie for dinner that night.
box front box rear
Being an 'L' kit, the Type L sits shorter than the Type H at just 34.27 (1.35"). Sitting at approximately the same height as most other memory modules that comprise a double height cooler, the Type L is perfect for those who are short on space but still require good memory cooling.
cooler 3 cooler 4
The Type L uses the same design features of the Type H in that each module has a heatpipe attached to both sides of the base plate. This heatpipe then winds through 180 degrees, threading itself through the finned array to dissipate the heat it wicked away from the base plate.
perspective 1 cooler 4
With each cooler sitting side by side it is clear that it is going to be a tight squeeze fitting these next to each other in the DIMM slots on any motherboard. However, once both are 'test fitted', there does indeed seem to be sufficient space to use both kits alongside one another.
together 1 together 2
Installing the modules was very straightforward. After taking the usual anti static precautions and banning the editor from sneaking up behind me to rub a balloon on my head after the previous comments I made, I set about installing each of the six kits. Luckily for me I happened to have 12GB of Kingston Value ram laying around which was perfect for this test in that I did not have to remove any heatspreader to get to the modules inside. After giving the IC's the once over with some Isopropyl Alchohol, I removed the backing from one strip of the thermal pads and then attached the pad to the module. While the 0.5mm pads were sticky, they were not overly so and could be used on multiple mounts with the minimal of fuss.
stock memory pad1
With the pads in place, I then began to attach the memory cooler which simply slid over the thermal pad with very little force. The memory cooler exacted just enough force to clamp down on the memory module to hold the thermal pad in place. Rinse and repeat for the rest of the modules and I was then ready to test them out to see the fruits of my labour.
slide on in place
Let's take a look at the test setup I used and installation of the Thermalright HR-07 modules on the motherboard...
«Prev 1 2 3 4 5 Next»
21-06-2009, 12:58:47
them sinks are dangerously epicQuote
21-06-2009, 14:01:58
Nice review as usual.
One issue;
Test Setup
For today's testing we will be using the Gigabyte EX-58 UD5, a mid-range Core i7 motherboard from Gigabyte that will allow us to push the memory on test to its absolute limit. Here's a breakdown of the rest of the components:
Intel Core i7 920 'Nehalem' @ 2.66Ghz
DFI Lanparty T3eH6 DK
I wonder if they made they a bit thinner it'd be easier to fit and would still cool them?
Nice idea though, really does look better than plain DIMMsQuote
21-06-2009, 14:18:31
Looks like an ace set, although the price hurts :X. Also, I don't think it would fit on my UD5 with noctua cooler. Even as it is now the fan goes a few mm into the DDR3_4 slot (iirc) airspace.Quote
21-06-2009, 14:20:13
ARe they any dif from stock coolers? LOL not going to mis those are you.
Be nice to know if there was a temp diffeerence from the inside to the outside modules.
All the same another great review webboQuote
21-06-2009, 14:38:09
$150 for a tri-chan setup is just too much, especially since there's nothing extra fancy about these coolers
if they were $30 each it'd be much easier to swallowQuote
