Thermalright Silver Arrow ITX Review
Performance and Testing
The test set up consisted of the following
Intel i7 3960X [email protected] 1.1v (undervolted) 4.0GHz @ 1.25v 4.4GHz @ 1.35v 4.6GHz @ 1.45v Gigabyte X79 UD3 Corsair Vengeance LP Memory Corsair HX850 V2 Corsair Force GT 60GB Coolermaster Storm Trooper.
The graphs are now in jpeg format for all the mobile device users out there and are placed in order with the best performing at the top so as to help better visualise where the cooler we're testing comes in the pack.
As usual we'll be testing our coolers at varying levels of overclock and increasing levels of voltage.  This in turn of course means increasing levels of heat which the coolers need to dissipate.  To begin with we start with the undervolted stock speed.  Why undervolted? well if you have things set on "Auto", you may well be using more volts than are actually required to run at the chosen frequency, for example our 3960s will run quite happily at just 1.1volts, solid as a rock, 24/7, and as such we use this as our starting point.
Continuity is very important in testing, and for this reason we keep as many of the potential variables as locked down as possible.  We will be using OCCT in Linpack X64, AVX compatible with all logical cores tested and 90% free memory utilised. The test is set up to run automatically with just a few clicks to set it going.  A 10 minute idle followed by 30 minutes of testing and a 5 minute cool down is the order of the day and brings the total test time per clock speed to 45 minutes.  So as to remove subjectivity in determining whether a CPU has failed, OCCT is set to stop the test and register a fail should the max temp exceed 80 degrees.  In testing we noted that if even just one of the cores exceeds 82 degrees OCCT halts the test and a fail is recorded.
Keeping in mind that the Silver Arrow ITX is not intended to compete with the likes of the D-15 or D15 we think it makes a reasonable fist of this entry level test.  We of course run all tests at the full 12 volts, which for the ITX translates to a very quiet 24.9dB(A).
Turning now to the 4GHz test we up the voltage to 1.25 volts, this is what is deemed normally as stock volts. Something we are always harping on about on the forums is AUTO does not mean stock volts, and normally if you overclocking with "auto" volts the motherboard will be upping the volts much more than needed if you were to do it manually. By whichever means it happens, upping the volts (especially from our 1.1v undervolt) does have a big impact on temps, with an average increase of 10-15 degrees seen in the results.
At the higher levels of heat generated by the increase in voltage required for the 4.0GHz overclock, fan performance, although still a factor becomes less critical, replaced instead by a coolers ability to conduct the heat up the heat pipes and more crucially the total surface area of the fins enabling convection to the atmosphere.  In the case of AIOs and water cooling the surface area of the radiator and the efficiency of the contact plate begin to play more of a role.
The ITX has slipped down the charts a bit, most noticeably giving up some places to the brace of bequiet coolers.  bequiet by name and by nature, but we'd have to say not nearly as quiet as the Silver Arrow.
Upping the volts still further we achieve a stable 4.4GHz overclock at 1.35 Volts. It's here we start to separate the wheat from the chaff, with lesser coolers not able to disperse the increased heat effectively. Again we see a jump of 10 degrees or so from the figures at 4GHz. Both the H100 and the well-respected D14 are creeping into the 70s here, indicating that only the cream of the crop will excel at this level.
The Silver Arrow isn't quite bottom of the pile, but it's not far off.  But again let's remind ourselves that this cooler has a single 140mm fan, is very quiet and won't cause you any RAM encroachment issues.  The same can't be said for the coolers above it in the charts.
«Prev 1 2 3 4 5 6 7 Next»
07-01-2015, 07:22:40
tonschk
Good review, nice to see you are using gloves, other reviewers don't care about fingerprints left all over the hardwareQuote
16-03-2015, 15:37:15
doyll
Nice review! Good cooler, in fact rather amazing considering it lost 2 pipes and a fan.
Was wondering where you are monitoring the air temperature for calculating delta temps. Is it the room or the actual temp of air going into cooler / radiator?Quote
